[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Yann Chemin
ychemin at gmail.com
Mon Aug 7 15:42:32 EDT 2006
On 08/08/06, Markus Neteler <neteler at itc.it> wrote:
> On Tue, Aug 08, 2006 at 02:03:29AM +0700, Yann Chemin wrote:
> > I'd like to think we can make a C code to automatically create a menu
> > description file instead of making it by hand all the time. If you
> > could separate it well from the other coding, it should make that task
> > easier when we'll come to it.
> > Additionally, since Python GUI does not need recompiling, it should
> > then be possible to generate "flavors" of GRASS, i.e. for image
> > processing or for GIS analysis, etc on the fly by modifying menu
> > contents.
> > Yann
> I was always thinking of having a "keyword" section in the module/manual.
> Like this commands could be easily grouped (searched). Probably this
> could be also used for autogenerating such dedicated menus more easily.
> Markus
Yes, i guess you put a structure to that thing that was tickling my brain.
It should be possible to use such a feature to make autogeneration of menus...
If this could be started somehow it should be beneficial in the longer term.
Yann
