[GRASS-dev] GRASS & cygwin quite slow
Huidae Cho
grass4u at gmail.com
Mon Aug 7 19:43:47 EDT 2006
> > > > Executing external programs (e.g. using g.list to generate a list of
> > > > maps) doesn't work. The actual OpenGL rendering works fine.
> > > This bombs in the prototype wxPython UI too. Is this somehow different from
> > > other GRASS modules?
> > Oops. The NVIZ map browser uses "ls", not g.list.
> But that's irrelevant; it was getting stuck on calling g.gisenv to get
> GISDBASE etc. I've discovered that it seems to blocking on stdin;
> pressing Return in the terminal allows it to continue, until the next
> exec. Furthermore, running nviz as "nviz ... </dev/null" eliminates
> the problem. However, putting a redirection in the exec command itself
> doesn't help.
> Another major problem with MSys is that it uses its own virtual
> filesystem rooted at e.g. c:/msys/1.0. The shell takes care of
> translating command-line arguments, but this causes problems with
> scripts which write pathnames to files. E.g. etc/Init.sh sets GISDBASE
> in $GISRC to an MSys pathname (e.g. /home/glynn/grass-data) while the
> executables (being native Windows programs) need the real pathname
> (e.g. c:/msys/1.0/home/glynn/grass-data).
Windows path name conflicts with the ":" path separator used in many
shell scripts. Is the native Windows version of GRASS supposed to run only
under MSys? If so, we can add /c/msys/1.0 prefix to all path names
stored in GISRC. I think it's reasonable to require MSys to run GRASS
on Windows.
Huidae Cho
> I suspect that we'll need to replace Init.sh with a .bat/.cmd file for
> Windows. Either that, or find a shell which doesn't mess around with
> filenames.
> I'm not sure how this will affect other shell scripts. MSys' bash can
> recognise Windows pathnames, and doesn't attempt to translate them, so
> using e.g. GISDBASE=`g.gisenv GISDBASE` shouldn't be a problem. I
> don't know whether any other scripts write pathnames to files, though.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
