[GRASS-dev] [bug #4983] (grass) r.blend: the output name check is to strict
Maciek Sieczka via RT grass-bugs at intevation.de
Tue Aug 8 03:31:19 EDT 2006
Moreover, r.blend ignores --ovewrite flag:
   $ g.list rast | grep map1_blend
     map1_blend.b            map1_blend.g
     map1_blend.r
   $ r.blend --o first=map1 second=map2 output=map1_blend
     Raster map <map1_blend.r> already exists.
*I know* it *exists* - that's why I'm using --o switch; but it's ignored for
some reason.
I'm changing the subject to 'r.blend: the output name check doesn't work'.
Maciek
-------------------------------------------- Managed by Request Tracker
