[GRASS-dev] [bug #4987] (grass) malloc errors/declaration - 64
bit problems
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Aug 8 10:45:17 EDT 2006
On Tue, 8 Aug 2006, Request Tracker wrote:
> On Tue, Aug 08, 2006 at 04:10:04PM +0200, Roberto Flor wrote:
> Here my findings on 64 bit problems:
> Simple, potential error on 64 bit machines, really only for float case:
> ./vector/v.surf.idw/main.c: npoints_currcell = (long **)G_malloc(window.rows * sizeof(long));
> Hyper allocation, requires more memory than necessary:
> ./vector/v.surf.idw/main.c: search_list = (struct cell_list **)G_malloc(max_radius * sizeof(struct cell_list));
> ./vector/v.surf.idw/main.c: search_list_start = (struct cell_list **)G_malloc(max_radius * sizeof(struct cell_list));
> ./vector/v.surf.idw/main.c: points = (struct Point ***)G_malloc(window.rows * sizeof(struct Point));
> ./vector/v.surf.idw/main.c: points[row] = (struct Point **)G_malloc(window.cols * sizeof(struct Point));
> In all the case the sizeof shoul to be of a pointer.
The v.surf.idw are all my mistakes; well spotted and thanks for pointing
them out. To fix them, I guess the size of a pointer is always the same no
matter what type it points to, so is there a standard way of representing
it always, e.g. like sizeof(char *)? Or should we always write sizeof(long *),
sizeof(struct Point *) etc. as appropriate? Is it just a question of
programming style?
Paul
