[GRASS-dev] New installation for wxPython GUI
Michael Barton michael.barton at asu.edu
Thu Aug 10 19:55:41 EDT 2006
I think we'll need to switch to a buffered device context (DC) for graphics
to stop the flicker.
The disappearing screen is real weird. It's like any other window acts as an
eraser. I could try a static bitmap instead of a DC and see what happens.
But first I'm going to pose this question to Robin Dunn on the wxPython
list. Hopefully he'll have some sage advice.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Fri, 11 Aug 2006 01:50:55 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Trevor Wiens <twiens at interbaun.com>, David Finlayson
> <david.p.finlayson at gmail.com>, Jachym Cepicky <jachym.cepicky at centrum.cz>,
> Grass Developers List <grass-dev at grass.itc.it>, Yann Chemin
> <ychemin at gmail.com>
> Subject: Re: [GRASS-dev] New installation for wxPython GUI
> Michael Barton wrote:
>> This change in binding the paint event from the panel where the painting
>> goes on to the entire frame has bad effects on window resizing. It makes it
>> very choppy, unresponsive, and sometimes inaccurate.
>> Adding in the 3 lines to redraw the current image into the onFocus event is
>> also problematic. It causes the display to disappear (and sometimes
>> reappear) anytime you change focus.
> I haven't had any of the above problems.
>> I've uploaded a new version of mapdisp.py to try out (I'm a bit in the dark
>> because I only have sporadic access to a Debian machine).
> Now I there is no redrawing once the window is visible again.
>> I've added some event.Skip() lines to the event handlers. This will let them
>> continue to process other events while processing their own. So I'm hoping
>> it will help with the disappearing display when you pass another window over
>> it.
> I haven't noticed any change.
> Moritz
