[GRASS-dev] [bug #4992] (grass) man conflict
Request Tracker grass-bugs at intevation.de
Sat Aug 12 00:29:32 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4992
Subject: man conflict
grass obtained from: Trento Italy site
grass binary for platform: Compiled from source (through RPM with LSB locations)
GRASS Version: 6.1.0
db/drivers/mysql/mysql.html is converted to man1/mysql.1.gz which conflicts with the man page of the database application and causes this:
rpm -Uhv /usr/src/redhat/RPMS/i386/grass-6.1.0-1.centos4.i386.rpm
Preparing...                ########################################### [100%]
        file /usr/share/man/man1/mysql.1.gz from install of grass-6.1.0-1.centos4 conflicts with file from package mysql-4.1.20-1.RHEL4.1
'mysql' is anyway a misnomer for a manual about the use of db.connect and nobody will ever type 'man mysql' for it. The same goes for dbf, pg, odbc etc, so db/drivers/*/* should be excluded from conversion to man in man/Makefile .
-------------------------------------------- Managed by Request Tracker
