[GRASS-dev] Re: grass-dev Digest, Vol 4, Issue 43
Glynn Clements
glynn at gclements.plus.com
Sun Aug 13 04:54:25 EDT 2006
Michael Barton wrote:
> In a different vein, what about SVG instead of postscript for output from
> d.* commands?
The same issues would apply, although I would expect SVG rendering to
be faster, as it was designed primarily for video display rather than
hardcopy.
> Once in a GUI, both TclTk and wxPython can export their
> graphic canvases to postscript easily.
wxPython has a retained-mode canvas? Or is that feature based upon
using Xprint (or similar)?
