[GRASS-dev] [bug #4998] (grass) r.mapcalc rand (a, b): b-1 is
used instead of b
Maciej Sieczka
tutey at o2.pl
Mon Aug 14 07:06:32 EDT 2006
Glynn Clements napisa?(a):
> Request Tracker wrote:
>> $ r.mapcalc 'map=rand(1,100)'
>> $ r.info -r map
>> min=1
>> max=99
>> should be 100!
> The above is correct, although the documentation should be more
> explicit. The result of rand() is a pseudo-random value x such that:
> a <= x < b
> This definition results in consistent behaviour for both the integer
> and floating-point cases, as well as being consistent with most
> standard PRNG functions (which usually treat the upper bound as
> exclusive).
Is this really necessary? Isn't it counter intuitive?
>> $ r.mapcalc 'map=rand(1,1)'
>> 0%
>> no progress whatever, 100% CPU used
> This might a compiler error, although it should handle this
> explicitly.
> The above case will result in division by zero, typically causing
> SIGFPE to be thrown. r.mapcalc installs a signal handler for SIGFPE
> which sets a flag then returns. It appears that SIGFPE gets thrown
> continuously in this case.
> I've fixed this error, and updated the documentation to clarify the
> behaviour.
Thank you!
Maciek
