[GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
Markus Neteler
neteler at itc.it
Wed Aug 16 04:10:48 EDT 2006
Michael,
this bug I know for > 1 year. I hope that Martin submits his patch.
Markus
Michael Barton wrote on 08/16/2006 08:13 AM:
> I can confirm this. There seems no way to satify g.region. We've set the
> WIND file manually and still get the same error.
> We did a make distclean and recompiled today (15 August) and still have the
> same results. This is on an FC4 32bit system.
> I tried the identical actions on my Mac, using 6.1.0 binaries compiled 12
> August and had no trouble at all.
> Did something change with g.region? Could this be due to the parser changes
> that Markus mentioned earlier today?
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Isaac Ullah <isaac.ullah at asu.edu>
>> Date: Tue, 15 Aug 2006 18:07:09 +0000
>> To: <grass-dev at grass.itc.it>
>> Subject: [GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
>> Hi all,
>> A very interesting and frustrating problem has just presented
>> itself to me. The region settings seem to "break" after using the new
>> zoom tools from the map display. i get the following error message in
>> the Output window:
>> region for current mapset is invalid
>> line 15: <depths: 0>
>> run "g.region"
>> This message displays after zooming a few times, or after attempting
>> to do anything at all with "g.region" (including just printing region
>> settings). Also, all the new zoom tools in the map display seem to do
>> nothing after this message, and I cannot display any of the maps in my
>> mapset. I have looked at the WIND file for the afflicted mapsets, and
>> they seem perfectly normal. For example, the above error message is
>> associated with the following WIND file:
>> proj: 1
>> zone: 36
>> north: 3742844.70455
>> south: 3309044.70455
>> east: 944264.754065
>> west: 560076.932184
>> cols: 12806
>> rows: 14460
>> e-w resol: 30.0006108
>> n-s resol: 30
>> top: 1
>> bottom: 0
>> cols3: 12806
>> rows3: 14460
>> depths: 1
>> e-w resol3: 30.0006108
>> n-s resol3: 30
>> t-b resol: 1
>> Making a new mapset allows me to run "g.region" without any problems
>> until I use the new zooming tools, and then the same problem occurs.
>> Restarting GRASS initially allows for the maps to be displayed again,
>> but after zooming a bit, or trying to run "g.region" again, the region
>> eventually "breaks" again. What I specifically do not understand is why
>> the error tells me to run "g.region" when doing so does nothing, and
>> seems to even cause the error in the first place. Does anybody have any
>> idea what the issue is here? I am using GRASS 6.3, compiled from the CVS
>> source yesterday (08/15)... Any help would be greatly appreciated.
>> Cheers,
>> Isaac
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
