[GRASS-dev] [bug #5008] (grass) r.neighbors: add null pass-through support
Wed Aug 16 10:18:03 EDT 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5008
> Subject: r.neighbors: add null pass-through support
> Maybe for completeness/correctness it should have an option to return a value
> of null when there is ANY null data as part of the calculation, shrinking the
> map at the region bounds and around any null cells, as mathematically the
> neighborhood analysis is only 100% valid in these areas. (-s strict?)
Agreed. There should be an option to propagate nulls.
