[GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
Martin Landa
landa.martin at gmail.com
Wed Aug 16 12:30:22 EDT 2006
Hi all,
I will submit this patch as soon as I have CVS write access...
Best, Martin
2006/8/16, Markus Neteler <neteler at itc.it>:
> Michael,
> this bug I know for > 1 year. I hope that Martin submits his patch.
> Markus
> Michael Barton wrote on 08/16/2006 08:13 AM:
> > I can confirm this. There seems no way to satify g.region. We've set the
> > WIND file manually and still get the same error.
> > We did a make distclean and recompiled today (15 August) and still have the
> > same results. This is on an FC4 32bit system.
> > I tried the identical actions on my Mac, using 6.1.0 binaries compiled 12
> > August and had no trouble at all.
> > Did something change with g.region? Could this be due to the parser changes
> > that Markus mentioned earlier today?
> > Michael
> > __________________________________________
> > Michael Barton, Professor of Anthropology
> > School of Human Evolution & Social Change
> > Center for Social Dynamics & Complexity
> > Arizona State University
> > phone: 480-965-6213
> > fax: 480-965-7671
> > www: http://www.public.asu.edu/~cmbarton
> >> From: Isaac Ullah <isaac.ullah at asu.edu>
> >> Date: Tue, 15 Aug 2006 18:07:09 +0000
> >> To: <grass-dev at grass.itc.it>
> >> Subject: [GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
> >> Hi all,
> >> A very interesting and frustrating problem has just presented
> >> itself to me. The region settings seem to "break" after using the new
> >> zoom tools from the map display. i get the following error message in
> >> the Output window:
> >> region for current mapset is invalid
> >> line 15: <depths: 0>
> >> run "g.region"
> >> This message displays after zooming a few times, or after attempting
> >> to do anything at all with "g.region" (including just printing region
> >> settings). Also, all the new zoom tools in the map display seem to do
> >> nothing after this message, and I cannot display any of the maps in my
> >> mapset. I have looked at the WIND file for the afflicted mapsets, and
> >> they seem perfectly normal. For example, the above error message is
> >> associated with the following WIND file:
> >> proj: 1
> >> zone: 36
> >> north: 3742844.70455
> >> south: 3309044.70455
> >> east: 944264.754065
> >> west: 560076.932184
> >> cols: 12806
> >> rows: 14460
> >> e-w resol: 30.0006108
> >> n-s resol: 30
> >> top: 1
> >> bottom: 0
> >> cols3: 12806
> >> rows3: 14460
> >> depths: 1
> >> e-w resol3: 30.0006108
> >> n-s resol3: 30
> >> t-b resol: 1
> >> Making a new mapset allows me to run "g.region" without any problems
> >> until I use the new zooming tools, and then the same problem occurs.
> >> Restarting GRASS initially allows for the maps to be displayed again,
> >> but after zooming a bit, or trying to run "g.region" again, the region
> >> eventually "breaks" again. What I specifically do not understand is why
> >> the error tells me to run "g.region" when doing so does nothing, and
> >> seems to even cause the error in the first place. Does anybody have any
> >> idea what the issue is here? I am using GRASS 6.3, compiled from the CVS
> >> source yesterday (08/15)... Any help would be greatly appreciated.
> >> Cheers,
> >> Isaac
> > grass-dev mailing list
> > http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
