[GRASS-dev] wxpython gui: speed of display
Glynn Clements
glynn at gclements.plus.com
Wed Aug 16 21:36:15 EDT 2006
Michael Barton wrote:
> What's the difference between
> GRASS_PNG_AUTO_WRITE and GRASS_RENDER_IMMEDIATE?
GRASS_PNG_AUTO_WRITE tells the PNG driver to write the image to a file
whenever a client disconnects, rather than waiting until you stop the
monitor.
GRASS_RENDER_IMMEDIATE tells the raster library to use its built-in
PNG driver rather than connecting to an external monitor process using
sockets.
> Isn't there also a flag on each d.command to have it output directly to a
> PNG/PPM file without runing d.mon?
There isn't a flag; that's what GRASS_RENDER_IMMEDIATE is for. A flag
would have to be implemented separately for each module, while an
environment variable read by the raster library automatically enables
this feature for all display modules.
