[GRASS-dev] compilation issues with lex
Markus Neteler
neteler at itc.it
Thu Aug 17 08:14:02 EDT 2006
On Thu, Aug 17, 2006 at 01:05:28PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > I have started to compile the well known software on
> > > > the new geodata blade of OSGeo nad encountered a few
> > > > problems:
> > > > cd lib/db/sqlp
> > > > make
> > > > gcc -I/mnt/home/neteler/software/grass6_cvs/dist.i686-pc-linux-gnu/include -g -Wall -pedantic -Werror-implicit-function-declaration -fno-common -fPIC -DPACKAGE=\""grasslibs"\" -DPACKAGE=\""grasslibs"\" -I/mnt/home/neteler/software/grass6_cvs/dist.i686-pc-linux-gnu/include \
> > > > -o OBJ.i686-pc-linux-gnu/lex.yy.o -c lex.yy.c
> > > > lex.l: In function 'yylex':
> > > > lex.l:76: error: implicit declaration of function 'strdup'
> > > > cd raster/r.mapcalc
> > > > [neteler at xblade11-2 r.mapcalc]$ make
> > > > gcc -I/mnt/home/neteler/software/grass6_cvs/dist.i686-pc-linux-gnu/include -g -Wall -pedantic -Werror-implicit-function-declaration -fno-common -DPACKAGE=\""grassmods"\" -I/mnt/home/neteler/software/grass6_cvs/dist.i686-pc-linux-gnu/include \
> > > > mapcalc.l: In function 'yylex':
> > > > mapcalc.l:134: error: implicit declaration of function 'strdup'
> > > strdup() is defined in <string.h>, but it isn't ANSI and you're using
> > > -pedantic.
> > The problem remains when I don't use -pedantic.
> > I assume that -Werror-implicit-function-declaration is the problem
> > now:
> > MYCFLAGS="-g -Wall -Werror-implicit-function-declaration -fno-common"
> > MYCXXFLAGS="-g -Wall"
> It shouldn't be; with the default feature macros (i.e. _GNU_SOURCE),
> including <string.h> should declare strdup().
> OTOH, I'm a bit confused by:
> lex.l:76: warning: incompatible implicit declaration of built-in function 'strdup'
> which suggests that strdup() is a built-in function. strdup() isn't a
> particularly obvious choice for a built-in function; most built-in
> functions tend to be something which can be implemented in a handful
> of CPU instructions, e.g. memset, memcpy, etc.
> I suggest looking at the logic surrounding the declaration of strdup()
> in string.h, in case that provides any clues.
Here we are:
/usr/include/string.h:
#if defined __USE_SVID || defined __USE_BSD || defined __USE_XOPEN_EXTENDED
/* Duplicate S, returning an identical malloc'd string. */
extern char *strdup (__const char *__s)
__THROW __attribute_malloc__ __nonnull ((1));
#endif
rpm -qf /usr/include/string.h
glibc-headers-2.3.6-3
cat /etc/issue
Fedora Core release 4 (Stentz)
Kernel \r on an \m
uname -a
Linux xblade11-2 2.6.17-1.2142_FC4 #1 Tue Jul 11 22:41:14 EDT 2006 i686 athlon i386 GNU/Linux
rpm -qf `which lex`
flex-2.5.4a-40.fc4
On my RHEL4 office box I have
#endif
which looks identical to me (there no problem).
Anything else I should look for?
thanks
Markus
