[GRASS-dev] compilation issues with lex
Markus Neteler
neteler at itc.it
Thu Aug 17 10:08:21 EDT 2006
On Thu, Aug 17, 2006 at 02:09:04PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > OTOH, I'm a bit confused by:
> > > lex.l:76: warning: incompatible implicit declaration of built-in function 'strdup'
> > > which suggests that strdup() is a built-in function. strdup() isn't a
> > > particularly obvious choice for a built-in function; most built-in
> > > functions tend to be something which can be implemented in a handful
> > > of CPU instructions, e.g. memset, memcpy, etc.
> > > I suggest looking at the logic surrounding the declaration of strdup()
> > > in string.h, in case that provides any clues.
> > Here we are:
> > /usr/include/string.h:
> > #if defined __USE_SVID || defined __USE_BSD || defined __USE_XOPEN_EXTENDED
> > /* Duplicate S, returning an identical malloc'd string. */
> > extern char *strdup (__const char *__s)
> > __THROW __attribute_malloc__ __nonnull ((1));
> > #endif
> That's essentially what's in mine. Check that there isn't a private gcc
> verion in /usr/lib/gcc[-lib]/<arch>/<version>/include.
Here is what I found:
[neteler at xblade11-2 ~]$ l /usr/lib/gc
gcc/ gcc-lib/ gcj/ gcj-4.0.0/ gcj-4.0.2/ gconv/ gcrt1.o
-> looks ok
[neteler at xblade11-2 ~]$ l /usr/lib/gcc/i386-redhat-linux/4.0.2/
adainclude/ libgcc_s.so libmudflap.a
adalib/ libgcjawt.so libmudflap.so
crtbegin.o libgcj.so libmudflapth.a
crtbeginS.o libgcj.spec libmudflapth.so
crtbeginT.o libgcov.a libobjc.a
crtend.o libgfortran.a libobjc.so
crtendS.o libgfortranbegin.a libstdc++.a
include/ libgfortran.so libstdc++.so
libgcc.a libgij.so libsupc++.a
libgcc_eh.a lib-gnu-java-awt-peer-gtk.so
-> looks ok
[neteler at xblade11-2 ~]$ l /usr/lib/gcc-lib/i386-redhat-linux/
2.96/ 3.2.3/ 3.3.4/
[neteler at xblade11-2 ~]$ ls /usr/lib/gcc-lib/i386-redhat-linux/2.96/
crtbegin.o crtbeginS.o crtend.o crtendS.o libgcc.a libgcc_eh.a
[neteler at xblade11-2 ~]$ rpm -qf /usr/lib/gcc-lib/i386-redhat-linux/2.96/libgcc.a
compat-libgcc-296-2.96-132.fc4
[neteler at xblade11-2 ~]$ ls /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/
cc1 cpp0 crtbeginT.o f771 libg2c.a libgcc_eh.a libstdc++.so tradcpp0
cc1plus crtbegin.o crtend.o include/ libg2c.so libgcc_s.so libsupc++.a
collect2 crtbeginS.o crtendS.o libfrtbegin.a libgcc.a libstdc++.a specs
[neteler at xblade11-2 ~]$ rpm -qf /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/crtbegin.o
compat-gcc-32-3.2.3-47.fc4
[neteler at xblade11-2 ~]$ ls /usr/lib/gcc-lib/i386-redhat-linux/3.3.4/
libstdc++.a libstdc++.so libsupc++.a
[neteler at xblade11-2 ~]$ rpm -qf /usr/lib/gcc-lib/i386-redhat-linux/3.3.4/libstdc++.so
compat-gcc-32-c++-3.2.3-47.fc4
> If there isn't,
> I have no idea why it's saying "implicit declaration".
> It might be worth checking lex.yy.c, to ensure that the
> "#include <string.h>" is getting copied there.
[neteler at xblade11-2 sqlp]$ pwd
/home/neteler/software/grass6_cvs/lib/db/sqlp
[neteler at xblade11-2 sqlp]$ grep string lex.yy.c | grep inclu
#include <string.h>
The code piece in lex.yy.c is:
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
* for details.
/**************** C-CODE *****************/
#line 24 "lex.l"
#include <grass/sqlp.h>
#include "y.tab.h"
#include <string.h>
#undef YY_INPUT
#define YY_INPUT(b, r, ms) (r = my_yyinput(b, ms))
Thanks for your patience. Maybe it's a gcc mystery.
Markus
