[GRASS-dev] Re: gis.m: resolution not preserved
Michael Barton
michael.barton at asu.edu
Fri Aug 18 11:48:28 EDT 2006
I posted a message on this over a week ago and got no reply.
<http://grass.itc.it/pipermail/grass-dev/2006-August/024866.html>
I also discovered this and thought it was a bug at first. But when I looked
at the code (this new 'explore mode' was developed by Cedric Shock), I
realized that it was intentional.
That is, it is dynamically changing resolution to speed display times as you
zoom in and out.
I asked if this is what we wanted or not. There are advantages and
disadvantages. It needs to be documented in any case, of course.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciej Sieczka <tutey at o2.pl>
> Date: Fri, 18 Aug 2006 12:12:32 +0200
> To: Michael Barton <michael.barton at asu.edu>, grass-dev
> <grass-dev at grass.itc.it>
> Cc: Jarek Jasiewicz <jarekj at amu.edu.pl>
> Subject: gis.m: resolution not preserved
> Michael,
> There is a problem with resolution handling in gis.m (6.3 CVS and 6.1).
> It's not preserved when zooming, and switching to "Map fills display
> window" corrupts it.
> Start Grass in spearfish.
> # terminal:
> g.region rast=slope -a
> # gis.m
> add raster 'slope'
> display it
> # gis.m CLI
> g.region -g
> n=4928030
> s=4913690
> w=589980
> e=609000
> nsres=30
> ewres=30
> rows=478
> cols=634
> # gis.m
> zoom in/out a bit
> # gis.m CLI
> g.region -g
> n=4925065.04215
> s=4921067.9817
> w=593703.886256
> e=599027.771749
> nsres=30.05308609
> ewres=30.07844911
> rows=133
> cols=177
> As you see, the resolution is not preserved.
> It's even worse if you switch to "Map fills display window" mode: once
> you do it, the resolution goes really funky:
> # gis.m CLI
> g.region -g
> n=4925065.04215
> s=4921067.9817
> w=593703.886256
> e=599027.771749
> nsres=8.29265654
> ewres=8.29265653
> rows=482
> cols=642
> I tried adding -a for g.region calls in mapcanvas.tcl and it seems to
> solve the problem, but I'm not entirely sure which g.region calls really
> require it, and which should be be left without it. Moreover, I don't
> know how to fix the "Map fills display window" resolution bug.
> Also, it seems that rastnum.tcl and georect.tcl would require same fix (?).
> As I'm not sure how to fix these, can I ask you to take a look at them?
> Maciek
