[GRASS-dev] Keywords in module descriptions
Yann Chemin ychemin at gmail.com
Sun Aug 20 07:08:41 EDT 2006
This is great for auto-generation of menus, but also to try to find a
tool we dont know the name but we know what it should do.
On 19/08/06, Markus Neteler <neteler at itc.it> wrote:
> Hi,
> I have added the keywords now in GRASS 6.3-CVS.
> Each command has at least 1 keyword. We need to add
> more of course, but they should be selected from a list
> or so to avoid that identical things get different
> keywords. Here the Wiki may be of use.
> I have also updated all scripts for keyword support.
> So far I didn't touch the TclTk interface to make
> the keywords visible. I am not sure if this is really
> desired.
> Next week the HTML Web pages will contain the keywords.
> Please extend them, it's simply done by adding them:
> - in C programs:
>    module->keywords = _("a, b, ...");
> - in shell scripts:
>    keywords: a, b, ...
> Question: Should I apply the patch to GRASS 6.2-release branch
> as well?
> Enjoy,
> Markus
> On Thu, Aug 17, 2006 at 09:49:32PM +0200, Markus Neteler wrote:
> > Hi,
> > a proposal for a better navigatable documentation of GRASS:
> > I would like to add
> >     module->keywords = _("a, b, c, d");
> > to each command. These keywords would then
> > - automatically appear in each HTML/MAN page
> > - be content of the XML output by --interface-description
> >   (maybe parsable then <keywords>a, b, c, d</keywords> for
> >    automated GUI arranging?)
> > - probably made visible in the TclTk GUI if we want that
> > - visible in the "help" text, example:
> > r.cost help
> > Description:
> >  Outputs a raster map layer showing the cumulative cost of moving between different geographic locations on an input raster map layer whose cell category values represent cost.
> > Keywords:
> >  raster map, cost surface, cumulative costs
> > Usage:
> >  r.cost [-vknr] input=name output=name [start_points=string]
> >    [stop_points=string] [start_rast=string] [coordinate=x,y[,x,y,...]]
> >    [stop_coordinate=x,y[,x,y,...]] [max_cost=cost] [null_cost=null cost]
> >    [percent_memory=percent memory] [--overwrite]
> > I have it running on my PC for r.cost.
> > With a sed job I could substitute all
> >    module->description = ...
> > by
> > automatically.
> > Maybe we could make a Web application to visualize the keywords
> > like a navigatable tree or "TouchGraph" [1] or whatever appropriate.
> > Any objections?
> > Markus
> > [1] Just as an selfish example (needs Java):
> >     http://www.citeulike.org/nocrawl/touchgraph_applet.adp?article_id=172900
> >     (double click on the floating objects to navigate)
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
