[GRASS-dev] batch-grass.sh not working with GRASS > 6.0
Robert Nuske
rnuske at gwdg.de
Mon Aug 21 08:30:51 EDT 2006
Markus,
with the help of the wiki page you mentioned, I discovered that batch-grass.sh
is missing at least:
- LD_LIBRARY_PATH
- GIS_LOCK
- cleanup routine
where $GISBASE/lib in the LD_LIBRARY_PATH seems to be vital.
The broken batch-grass.sh is still on this website:
http://grass.itc.it/faq/index.html
It should be stated that the script is not working with newer versions of
GRASS or fixed accordingly.
Since I found batch-grass comfortable for running the same script in different
mapsets over night, I updated it. I attached my version of batch-grass.sh,
which is working with all 6.x versions, in case you want to replace the
broken one.
cheers,
robert
Am Freitag 18 August 2006 13:44 schrieb Markus Neteler:
> Robert,
> please run the script with
> sh -x scriptname
> to better understand what happens.
> We have a Wiki page dedicated to Shell batch jobs:
> http://grass.gdf-hannover.de/wiki/GRASS_and_Shell
> which may also be of help.
> Markus
> On Fri, Aug 18, 2006 at 12:29:42PM +0200, Robert Nuske wrote:
> > Dear Developers,
> > does anybody know why batch-grass.sh
> > from the GRASS FAQ "How to use GRASS in batch mode?"
> > does not work anymore?
> > I run the batch-grass.sh script for the last time successfully in May
> > with whatever cvs version was up-to-date at that time, probably 6.1.
> > After fiddling with my grass-scripts and cluelessly looking through
> > batch-grass.sh I tested all 6.x versions and found that my set-up works
> > with the 6.0 version but not with the newer versions.
> > Thats why I am wondering what changed in GRASS to that effect. And what
> > do I need to do, to get batch-grass.sh working again.
> > I very much appreciate any hints, tips and fixes.
> > cheers,
> > robert
> > --tests-----------------------------------------------------------
> > simple test with one command:
> > ./batch-grass.sh eifel nwz2 g.region -p
> > 6.0.2 is okay
> > grass-6.1.0 - 6.3.cvs give the following
> > ./batch-grass.sh: line 62: 16750 Speicherzugriffsfehler $*
> > providing the grass commands in a file:
> > ./batch-grass.sh eifel nwz2 -file g_commands.sh
> > grass-6.0.2 again works
> > and the others fail with this message:
> > sh: line 1: 17129 Speicherzugriffsfehler g.region -p
> > with:
> > grass-6.3.cvs (cvs from 2006-08-17)
> > grass-6.2.cvs (built from grass-6.2.cvs_src_snapshot_2006_08_12)
> > grass-6.1.0 (built from grass-6.1.0.tar.gz)
> > grass-6.0.2 (built from grass-6.0.2.tar.gz)
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
Type: application/x-shellscript
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060821/2f71f331/batch_new.bin
