[GRASS-dev] SQLite as default DB in GRASS 6.3+
Brad Douglas
rez at touchofmadness.com
Wed Aug 23 18:07:26 EDT 2006
On Thu, 2006-08-24 at 01:19 +1200, Hamish wrote:
> shall we now go ahead and make SQLite the default DB for GRASS 6.3+?
Hamish,
I do have some concern over SQLite's performance under large data sets.
SQLite was not designed for data mining, but as a lightweight DBMS and
middleware for others, IIRC.
However, SQLite is quite easy to use. I don't see a big problem making
it the default since it's simple switch to another. Anyone else?
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
