[GRASS-dev] [bug #5042] (grass) v.digit: Settings pop-up off
the screen
Hamish
hamish_nospam at yahoo.com
Wed Aug 23 22:48:34 EDT 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5042
> http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=305247
> > On a 800x600 monitor, the Settings pop-up window comes up always
> > partially off the screen and has to be manually moved back.
> > Besides, the rightmost main menu Exit button is also half cut off.
> Does this refer to placement or the the windows size?
> GRASS is not doing placement.
> I assume that you mean size: in fact the window exceeds
> 800 pixels in widths which should be somehow fixed (smaller
> icons?).
> cc GRASS bugtracker.
xwininfo show the window has:
Width: 813
Height: 146
So we don't need much.
There are 22 icons across, most are 32x32. Some are smaller, e.g.
zoom.*.gif. Most could be cropped or edited to 30x30 without much
damage.
Alternate, maybe better: move first 11 icons below last 11 (natural
break there), this results in a 2x11 block of icons.
It's set at line 76 of vector/v.digit/toolbox.tcl, but I don't know
enough tcl to make it into two rows. help?
Hamish
