[GRASS-dev] [bug #5043] (grass) r.out.gdal does not
export "g.region -p"
William Kyngesburye
woklist at kyngchaos.com
Thu Aug 24 11:11:36 EDT 2006
I knew there was another reason I preferred r.out.tiff (besides
easier to remember options). r.out.tiff uses the region settings.
On Aug 24, 2006, at 9:17 AM, Maciej Sieczka wrote:
> Markus Neteler napisa?(a):
>> On Thu, Aug 24, 2006 at 02:11:12PM +0200, Request Tracker wrote:
>>> this bug's URL: http://intevation.de/rt/webrt?serial_num=5043
>>> Subject: r.out.gdal does not export "g.region -p"
>>> Platform: GNU/Linux/x86
>>> grass obtained from: Other (CDROM etc)
>>> grass binary for platform: Downloaded precompiled Binaries
>>> GRASS Version: GRASS 6.0.2 (2006)
>>> r.out.gdal does export the region as defined in "g.region -p",
>>> but the full input raster file.
>> I just found that it is pretty easy to support at least
>> the current region extent:
>> diff -u -r1.24 r.out.gdal
>> --- r.out.gdal 19 Aug 2006 12:52:24 -0000 1.24
>> +++ r.out.gdal 24 Aug 2006 12:54:58 -0000
>> @@ -129,9 +129,11 @@
>> unset METAKEY
>> fi
>> +eval `g.region -g`
>> #do it
>> CELLHD=`echo $file | sed 's+/cell/+/cellhd/+g'`
>> echo "Writing format: $FORMAT"
>> echo "Writing type: $TYPE"
>> -gdal_translate -of $FORMAT -ot $TYPE $CREATEKEY $METAKEY $CELLHD
>> $OUTPUT
>> +gdal_translate -of $FORMAT -ot $TYPE $CREATEKEY $METAKEY -projwin
>> $w $n $e $s $CELLHD $OUTPUT
>> For current resolution support, I have no idea.
>> Opinions about above change?
> I personally like the way r.out.gdal behaves now, as usually I need to
> export full rasters I create, not a parts of them. Present r.out.gdal
> bahaviour saves me fiddling with g.region prior to export. The
> trim-to-current-region behavior would be nice as an option though (no
> need for intermediate r.mapcalc then). My 0,01 PLN.
> As to resolution, maybe this would work:
> gdalwarp -of $FORMAT -ot $TYPE $CREATEKEY -te $w $n $e $s -tr $ewres
> $nsres $CELLHD $OUTPUT
> I don't know how to substitute gdal_translate's -mo in gdalwarp. -wo?
> Maciek
> P.S.
> If the gdalwarp approach would be OK, this report would become a
> duplicate of wish http://intevation.de/rt/webrt?serial_num=3271.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
