[GRASS-dev] [bug #2790] (grass) r.bilinear result is rounded to .5
Thu Aug 24 13:15:58 EDT 2006
Maciek Sieczka via RT wrote:
> Indeed r.bilinear doesn't produce atrifact .5 and stuff anymore, but it's
> output is slightly different than the output of the new r.resamp.interp
> method=bilinear.
> See spearfish60 example:
> $ g.region rast=slope -a
> $ g.region res=10.95 -a
> $ r.bilinear input=slope output=slope_rbil
> $ r.resamp.interp input=slope output=slope_rinterp method=bilinear
> $ r.mapcalc 'diff=slope_rbil-slope_rinterp'
> There is a minimal difference...
> $ r.info -r diff
> min=-0.000000
> max=0.000000
> ... which can be seen on display as a kind off a regular pattern, and if
> exagerated x10^15 it is noticable as:
> $ r.mapcalc 'diff_exag=diff*10.0^15.0'
> $ r.info diff_exag -r
> min=-7.105427
> max=7.105427
That level of error can easily be attributed to differences in
rounding. It's by no means clear which of the two (if either) is more
accurate.
For IEEE FP, DBL_EPSILON is ~2.2e-16, so a value of ~7.1e-15 is
roughly 32 * DBL_EPSILON. "r.info slope" gives the range as roughly
0-52.5, so I'd expect to see errors of +/- 1.2e-14 (i.e. around 63%
more than you're actually getting).
Differences at that scale are irrelevant; there's no way that your
source data is going to be accurate to 16 digits (2.2e-16 is
equivalent to measuring the equatorial circumference to an accuracy of
10 nanometres).
