[GRASS-dev] freetype on gentoo
Fri Aug 25 10:57:08 EDT 2006
Glynn Clements wrote:
> I'll try building with --disable-<everything> to see which modules
> require conditional compilation.
Done; I've fixed a couple of cases where this was missed (v.digit,
r.out.tiff).
I haven't fixed the modules which fail when --without-curses is used;
the number of modules which require it is such that curses is
effectively mandatory (both libgrass_I and libgrass_Iortho require it,
thus so do all imagery modules).
