[GRASS-dev] Keywords, help pages...
Trevor Wiens
twiens at interbaun.com
Tue Aug 29 00:43:25 EDT 2006
On Tue, 29 Aug 2006 14:45:21 +1200
Hamish <hamish_nospam at yahoo.com> wrote:
>...snip....
> AFAIK, a module was never specifically written for this as v.category
> could do it (if you knew about it).
> Rather than keywords and updated help pages, I offer the attached
> script as a more direct solution.
> If folks feel it more appropriate a new C modules using the
> Vect_get_point_in_area() function [lib/vector/Vlib/poly.c] directly
> could be written, but I think this script is fine for now.
> In a similar vein, a v.dissolve script could be written as a front end to
> "v.extract -d".
Hamish,
Thanks, that is a much better solution.
I like the idea of a v.dissolve script especially if it had the option
to dissolve according using the values in one of the columns of the
attached attribute table; it would be much quicker to use.
I could write description.html files for v.add.centroids and v.dissolve
if it would be helpful.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
