[GRASS-dev] hardcoded 'xterm': wrapper?
Maciej Sieczka
tutey at o2.pl
Tue Aug 29 10:45:54 EDT 2006
Glynn Clements wrote:
> It seems to work for me,
After this change any command from d.m that spawns terminal (d.zoom,
r.digit etc.) is broken on my Ubuntu Dapper, where gnome-terminal is a
default terminal.
In spearfish60:
$ d.m
add any layer
display it
press Zoom
gnome-terminal pops-up saying:
/usr/local/grass-6.3.cvs/etc/grass-run.sh: line 30: d.zoom: command not
found
ERROR: d.zoom exited abnormally. Press <enter> to continue.
And on the Grass terminal I get:
Option --tclass is no longer supported in this version of
gnome-terminal; you might want to create a profile with the desired
setting, and use the new --window-with-profile option
Maciek
