[GRASS-dev] grass63 -text startup screen
Michael Barton
michael.barton at asu.edu
Wed Aug 30 12:31:39 EDT 2006
This text is getting better and better.
I'd recommend changing "the" to "a" and removing the word "all" from the
DATABASE line.
DATABASE: This is a directory (folder) containing the GRASS locations.
There is no reason a user cannot have more than one "DATABASE", but GRASS
needs to know what the database is in order to find locations and mapsets.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Trevor Wiens <twiens at interbaun.com>
> Date: Wed, 30 Aug 2006 08:21:28 -0600
> To: Paul Kelly <paul-grass at stjohnspoint.co.uk>
> Cc: grass-dev <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] grass63 -text startup screen
> On Wed, 30 Aug 2006 14:57:49 +0100 (BST)
> Paul Kelly <paul-grass at stjohnspoint.co.uk> wrote:
>> Hello Maciek
>> I suggested some improved text a while ago:
>> http://grass.itc.it/pipermail/grass5/2006-July/024686.html
>> There were no objections - I will commit this if there still are none.
> Paul,
> Reading through the text at the link you provide the definition of
> database as a unix directory. Perhaps, since there are other platforms
> involved it should be rephrased to read
> DATABASE: This is the directory (folder) containing all the GRASS
> locations.
> I think this terminology would be more understandable to Mac/Windows
> users.
> I would suggest the following change for two additions for MAPSET. The
> first short sentence about a location containing one or more is
> intended to make clear that a MAPSET is a subset of a LOCATION. The
> second addition at the end is an introduction to the concept of
> managing data for different users, modified from the GRASS Quickstart
> page. Perhaps the second sentence is too long, but I think the first is
> a worthy addition.
> MAPSET: Every GRASS session runs under a particular MAPSET.
> [Addition1] Each LOCATION has one or more MAPSET.
> Associated with each MAPSET is a rectangular REGION and a set of maps.
> [Addition2] When creating a new location GRASS automatically creates a
> special MAPSET called PERMANENT, which is readable by other GRASS
> sessions accessing the LOCATION.
> T
>> Paul
>> On Wed, 30 Aug 2006, Maciej Sieczka wrote:
>>> Hi,
>>> Grass text startup screen says:
>>> LOCATION: This is the name of an available geographic location.
>>> -spearfish- is the sample data base for which all tutorials are written.
>>> This is not true and incomplete. How do I correct it? I suggest:
>>> LOCATION: This is the name of an available Grass location
>>> (data set). "spearfish" is the sample data set for which many
>>> tutorials are written. You can obtain it at http://grass.itc.it.
>>> OK?
>>> Maciek
>>> P.S.
>>> http://grass.itc.it/download/data.php contains:
>>> GRASS locations (databases)
>>> Let's not mix location and database. I think it could be:
>>> GRASS locations (data sets)
>>> instead.
>>> Maciek
>>> grass-dev mailing list
>>> http://grass.itc.it/mailman/listinfo/grass-dev
> Trevor Wiens
> The significant problems that we face cannot be solved at the same
> level of thinking we were at when we created them.
> (Albert Einstein)
