[GRASS-dev] Re: [bug #4905] (grass) gis.m: d.text.freetype does
not allow spaces in text
Huidae Cho
grass4u at gmail.com
Wed Aug 30 12:38:29 EDT 2006
On Wed, Aug 30, 2006 at 11:49:23AM +0200, Moritz Lennert wrote:
> >>>Is this fixed now? Freetype text doesn't work on a Mac so I can't tell.
> >>No, neither the gis.m part, nor the d.text.freetype part (for which I will
> >>post a separate bug report to make it more visible).
> >>As Glynn wrote, the gis.m error can be "solved" by typing
> >>d.text.freetype -n -b {text=Population totale}
> >>instead of
> >>d.text.freetype -n -b text="Population totale"
> >>But I don't find this solution very intuitive, especially as on the command
> >>line the second works.
> >>So maybe there should be some treatment in gis.m which translates the second
> >>version into something usable. Or at least the documentation has to be
> >>updated, but I would only consider this as a temporary solution.
> >>Just for memory, the d.text.freetype part of the bug is that even when a
> >>space is accepted, it is not printed on the screen, making the above into:
> >>Populationtotale
> >There are two separate issues. gis.m has previously had problems with
> >arguments containing spaces, but there have been some fixes in that
> >area. If you come across this problem in the current CVS version, file
> >a bug report.
> That is what this bug report is actually about (what I call the "gis.m part of
> the bug") and it is still open as of CVS-head from yesterday.
> >The problem with spaces disappearing is that FT_Render_Glyph() returns
> >an error for the space glyph, causing the code to ignore that glyph
> >(and, significantly, not advance the rendering position).
> But this only seems to be a problem with the current stable version of
> freetype, i.e. 2.2.1. Using latest CVS code of freetype, the problem is solved.
This is a related thread:
http://www.nabble.com/Error-rendering-space-character-in-mono-mode-with-FreeType-2.2.1-t1881988.html
Huidae
> >The code should probably still advance the rendering position in the
> >event that FT_Render_Glyph() fails.
> Is this a problem with anything else then space ?
> Moritz
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
