[GRASS-dev] [bug #5076] (grass) gis.m: freeze when zooming on
	Map Display 2 while Map Display 1 is being refreshed
    Michael Barton
    michael.barton at asu.edu
    Wed Aug 30 12:49:56 EDT 2006
I just added error trapping for trying to re-render 2 maps simultaneously.
What happens now is that the slower-rendering map just doesn't get rendered
and you have to click the render button again.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Wed, 30 Aug 2006 17:13:30 +0200 (CEST)
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] [bug #5076] (grass) gis.m: freeze when zooming on Map
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5076
> Subject: gis.m: freeze when zooming on Map Display 2 while Map Display 1 is
> being refreshed
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 2006-08-29
> In spearfish60.
> 1. $ grass63 -text
> 2. $ g.region rast=slope res=1 -a
> (setting res to 1 to slow down the display to make the bug easy to reproduce)
> 3. $ gis.m
> 4. add some raster, display it
> 5. start Map Display 2, add another raster
> 6. refresh Map Display 2 and try to press 'zoom in' on Map Display 1 while Map
> Display 2 is being refreshed - the outcome is:
> error renaming "/home/grassdata/spearfish60/sieczka/.tmp/sorbus/15530.0.ppm":
> no such file or directory
>     while executing
> "file rename -force $mapfile($mon) $lfile($id)"
>     (procedure "GmCommonLayer::display_commands" line 31)
>     invoked from within
> "GmCommonLayer::display_commands $namespace $id [list $cmd]"
>     (procedure "GmCommonLayer::display_command" line 2)
>     invoked from within
> "GmCommonLayer::display_command [namespace current] $id $cmd"
>     (procedure "GmRaster::display" line 71)
>     invoked from within
> "GmRaster::display $node $mod"
>     ("raster" arm line 2)
>     invoked from within
> "switch $type {
>         group {
>             GmGroup::display $node $mod
> raster {
> labels {
> GmLabels::disp..."
>     (procedure "GmTree::display_node" line 7)
>     invoked from within
> "GmTree::display_node $n $mod"
>     (procedure "GmGroup::display" line 25)
>     invoked from within
> "GmGroup::display "root" $mod"
>     (procedure "MapCanvas::runprograms" line 69)
>     invoked from within
> "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
>     (procedure "MapCanvas::drawmap" line 38)
>     invoked from within
> "MapCanvas::drawmap $mon"
>     (procedure "MapCanvas::display_server" line 9)
>     invoked from within
>     ("after" script)
> gis.m freezes, I have to kill -9 it's wish.
> I'm not saying that zooming on one display while the other is being refreshed
> must work (I don't think it is critical), but if the user tries to do such a
> thing (it's likely - the refresh takes long on Map Display 1, so he decides to
> use Map Display 2 in the meantime) it cannot result in a complete freeze of
> gis.m.
> Maciek
> -------------------------------------------- Managed by Request Tracker
