[GRASS-dev] Changes to r.sun made Feb 2006 [resolved]
Dylan Beaudette dylan.beaudette at gmail.com
Fri Dec 1 00:10:02 EST 2006
Sorry for the noise, it looks like this was an operator error on my part.
Cheers,
Dylan
PS: with even better results from r.sun:
http://169.237.35.250/~dylan/temp/11-yr_variation_vs_modeled.png
when using longer term averages, the R^2 goes to 0.95 ! (right hand
sub-figure), but still working on optimal Linke turbidity values.
On 11/28/06, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> Hi everyone,
> I am repeating an experiment, originally conducted Feb 7th 2006, comparing the
> output from r.sun with real data from a weather station.
> On Feb 7th, 2006 the output from r.sun (computed with customized linke
> turbidity values) very closely matched the weather station data.
> As of today the exact same experiment gives slightly different results:
> 1. the correlation between r.sun and the weather station is nearly identical
> 2. the output from r.sun (specifically the beam component) is about 1500
> Wh/sq. meter/day higher than it should be.
> The only thing that has changed since I last conducted this experiment was
> r.sun. From the CVS server it looks like r.sun/main.c was altered shortly
> after I did my original experiment:
> Revision 2.14 / (as text) / (view) - annotate - [select for diffs] , Tue Feb
> 21 10:00:52 2006 UTC (9 months ago) by markus
> Branch: MAIN
> Changes since 2.13: +28 -174 lines
> Diff to previous 2.13
> Jaro Hofierka: new shadow algorithm; dist param changed to fixed value;
> correction factor for shadowing to account for the earth curvature
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/raster/r.sun/main.c
> In summary, the diffuse component of the modeled solar radiation is nearly the
> same as it was when computed by r.sun Feb 7 2006. The beam component is now
> about 1500 Wh/sq m / day higher than it was as on Feb 7 2006.
> This brings up an interesting question: which results from r.sun where the
> most representative of reality ? I noticed that the changes made to r.sun
> involved a shadow algorithm- yet my weather station (and modeled area) are
> not greatly affected by the shadowing of adjacent terrain.
> Any thoughts on how to best proceed would be greatly appreciated.
> PS:
>  the original results were mentioned in a previous message to the GRASS list
> on Feb 8 2006.
> http://www.nabble.com/-GRASSLIST%3A10214--some-nice-results-from-r.sun-t1087635.html
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
