[GRASS-dev] r.out.gdal2 -> r.out.gdal?
Martin Landa
landa.martin at gmail.com
Fri Dec 1 12:30:30 EST 2006
+1 for r.out.gdal2 -> r.out.gdal(C)
maybe it could be safer to rename the r.out.gdal(script) to
r.out.gdal2 or r.out.gdal.sh and to add an appropriate warning, e.g.
WARNING: This module is superseded and will be removed in future
versions of GRASS. Use r.out.gdal instead.
Martin
2006/12/1, Markus Neteler <neteler at itc.it>:
> hi,
> are there objections to rename r.out.gdal2 to
> r.out.gdal and remove the now obsolete
> scripts/r.out.gdal/
> I have used the C version quite a bit successfully.
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
