[GRASS-dev] vask and undefined symbol: stdscr - was Re: [Gdal-dev]
Error accessing Pgeo through ODBC
Glynn Clements
glynn at gclements.plus.com
Fri Dec 1 18:45:35 EST 2006
Markus Neteler wrote:
> I have seen this message in the GDAL list:
> On Tue, Nov 28, 2006 at 11:03:00AM +1100, Craig Feuerherdt wrote:
> > I am using Gentoo Linux.
> > When I attempt to use ogrinfo I get the following errors:
> > ogrinfo PGeo:b_pgeo
> > ERROR 1: /usr/grass-6.1.0/lib/libgrass_vask.so: undefined symbol: stdscr
> > ERROR 1: /usr/grass- 6.1.0/lib/libgrass_vask.so: undefined symbol: stdscr
> > Segmentation fault
> > I can not work out why the error involves GRASS?
> cd lib/vask/
> grep stdscr *
> V_call.c: getyx (stdscr, y, x);
> V_exit.c: keypad(stdscr, 0);
> V_init.c: keypad(stdscr, 1);
> V_support.c: getyx(stdscr, cury, curx) ;
Note that most of the curses "functions" which don't begin with "w"
are actually macros which call the corresponding function with
"stdscr" as the target window, e.g.:
#define addch(ch) waddch(stdscr,ch)
#define addchnstr(str,n) waddchnstr(stdscr,str,n)
#define addchstr(str) waddchstr(stdscr,str)
... and so on.
My guess is that, in some curses implementations, stdscr might be a
macro. A normal GRASS binary distribution wouldn't be compatible with
such an implementation; you would need to re-compile GRASS.
