[GRASS-dev] v.in.db: even with "where=" option the entire table is copied
Martin Landa landa.martin at gmail.com
Sat Dec 2 03:09:34 EST 2006
2006/11/29, Markus Neteler <neteler at itc.it>:
> I have found a nice bug in v.in.db:
> Even when I use a "where=" SQL statement to limit the
> number of points fetched from the DB, the entire table
> is copied. The module uses db_copy_table() which isn't
> appropriate.
> v.extract builds a list of cats to copy, then uses
> db_copy_table_by_ints(). So far I failed to transfer
> this approach to v.in.db.
fixed in CVS and backported to 6.2
Martin
> Help appreciated...
> thanks
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
