[GRASS-dev] current grass 6.3.cvs cross compilation
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Sun Dec 3 05:39:52 EST 2006
Hmmmm, but I just tried a 6.2.0 source tree and used these instructions:
http://wiki.qgis.org/qgiswiki/BuildingWindowsBinaryOnLinux
... and it worked OK, too!
And all the GRASS libs it made are definitely shared DLLs.
(although I did not get GDAL support working, but that's not important
for me at this point)
Glynn Clements wrote:
> Benjamin Ducke wrote:
>> Bad news:
>> it seems impossible to cross-compile the current GRASS 6.3.cvs version.
>> Bsically, every module I try to compile for Win32 on my Linux box fails
>> with sth. like this:
>>  *** No rule to make target
>> `/home/benni/wingrass/source/grass6/dist.i586-pc-mingw32msvc/lib/libgrass_vect.so',
>> needed by
>> `/home/benni/wingrass/source/grass6/dist.i586-pc-mingw32msvc/bin/v.in.db.exe
>> Obviously, it should not be looking for libgrass_vect.so but for
>> libgrass_vect.dll !
>> I am still able to compile the same modules, using the same tools, in a
>> GRASS 6.1.CVS tree!
>> Maybe some change to the configure script or one of the GRASS makefiles
>> broke something?
> Odd.
> AFAICT, cross-compiling shared libraries should never have worked.
> SC_CONFIG_CFLAGS uses "uname" to determine the platform, which returns
> the build platform, not the host platform.
> It should be using either $host or the components $host_cpu,
> $host_vendor, and $host_os.
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
