[GRASS-dev] Re: [GRASS-user] v.surf.rst limitations?
Roberto Antolin
roberto at geomatica.como.polimi.it
Tue Dec 5 03:23:17 EST 2006
Hi Hamish and all,
Thank you for the update and the information :)
I'll merge this update to my v.surf.bspline version and try to send my
last updates today.
Cheers,
Roberto.
Hamish ha scritto:
>Hi Roberto,
>here are some updates for v.surf.bspline vs. today's CVS.
>The most important is not calling G_write_history() until after
>the raster map is closed with G_close_cell().
>Also:
>* added opt->guisection for some options to make the GUI less
>cluttered. (feel free to come up with a better name for the tab)
>* added G_command_history() to save the command line into the history
>file so you can later know what the input map and settings were, and
>G_put_cell_title() to set the output map title. (see r.resamp.interp)
>I think it is good policy that all modules which create a new raster map
>should use those.
>Hamish
Roberto Antolín Sánchez
Politecnico di Milano – Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 – 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519
email: roberto.antolin at polimi.it
