[GRASS-dev] Re: v.in.gpsbabel bug? (with es file)
Hamish
hamish_nospam at yahoo.com
Tue Dec 5 04:33:29 EST 2006
> Leonardo:
> > Hi all,
> > I'm testing v.in.gpsbabel but I found a not corrspondence between
> > tha datas associated to the point in gps and the datas associated
> > to the new vector.
> > If I use a gps Garmin 12 (not Etrex) the label associated to the
> > points (second column in the file
> > gps.csv, download by gpstrans) is not present in the table
> > associated to the vector (gpsbabel.dbf).
> > If I use gps Garmin 12 Etrex it works well (gpsbabel_etrex.dbf).
Davide:
> I think that the field is not correctly recognized by gpsbabel, the
> script make only textual manipulation on his output...
> It can be that gpsbabel download the column with a different tag from
> the other garmin gps, and this tag is not included in csv
> stylesheet... If the problem is only on one gps receiver model, I
> think it his hard to fix (we had to download a meaningless column for
> all others gps receivers), but if it is common problem, we had to fix
> it.
> Leonardo, please try watching on temporary files to see if I'm right.
> PS Please report if it happens on other receivers...
All our Garmins are currently out in the field. I can help test whenever
they get back.
Note that "date" column is really just the comments field. It so happens
that the default comment when you make a new waypoint is the current
time and date. As the user can change it to anything, v.in.gpsbabel
should not treat that field as a timestamp, just as a string comment.
regards,
Hamish
