[GRASS-dev] creating new location in krovak projection
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Dec 5 05:32:40 EST 2006
Hello Jachym
Those datum paramters are already in GRASS (and have been for several
years). The datum short name is hermannskogel, not that obvious and a bit
long, and not my choice but we can't change it now.
Interestingly the Slovak parameters are (very slightly) different from my
source - they must cover a slightly different part of the country or have a
different accuracy or something. This would need to be confirmed and
documented before adding them to the file. Hopefully the site you got them
from has some information?
Paul
On Fri, 1 Dec 2006, Jachym Cepicky wrote:
> hi,
> together with Martin, we prepared this patch for 6.3. It itroduces new
> geodetic datums for both - Czech and Slovak republic (previously, we had
> to edit PROJ_INFO by hand and add "towgs84" parameter there).
> not sure, if this belongs to 6.2 too, but it would be nice to have it
> there.
> Thanks
> Jachym
> On Tue, Nov 28, 2006 at 08:52:27PM +0100, Markus Neteler wrote:
>> On Tue, Nov 28, 2006 at 08:42:54PM +0100, Jachym Cepicky wrote:
>>> Hi,
>>> I would like to define new Location using
>>> projection krovak
>>> ellipsoid bessel
>>> when I come to question about projection, I specify "krovak" and hit
>>> Return, GRASS jumps imidietly to DEFNE THE DEFAULT REGION form (for
>>> defining boundary coordinates and resolution).
>>> When I try do specify new projection with g.setproj, it ends like this:
>>> GRASS 6.3.cvs (jtsk2):~ > g.setproj
>>> Please specify projection name
>>> Enter 'list' for the list of available projections
>>> Hit RETURN to cancel request
>>>> krovak
>>> ERROR: Projection krovak is not specified in the table
>>> Howto define location using krovak projection?
>> Hi Jachym:
>> the Krovak projection is missing from:
>> general/g.setproj/proj-parms.table
>> I don't know how to add it there. It would be good to get
>> general/g.setproj/README
>> updated on how to add more projections.
>> Markus
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> OFFICE:
> Department of Geoinformation Technologies
> Zemedelska 3
> 613 00, Brno
> Czech Republick
> e-mail: xcepicky at node.mendelu.cz
> URL: http://mapserver.mendelu.cz
> Tel.: +420 545 134 514
