[GRASS-dev] Re: autoconf, LOC_CHECK_VERSION_INT
Maris Nartiss
maris.gis at gmail.com
Tue Dec 5 17:01:11 EST 2006
I was trying to emerge GRASS 6.1.0 and 6.2.0 on my freshly installed
Gentoo ~x86 box, but it stopped on following error:
***** autoconf *****
configure.in:44: error: possibly undefined macro: AC_MSG_ERROR
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
As Radim also had following problem, I wan to ask:
1) is autoconf-2.1x required to compile GRASS and autoconf-2.61
currently banned?
2) if it is fixed in 6.3, is possible to backport this fix before 6.2.1 release?
3) is easy to fix this autoconf problem? I mean like changing one line
in configure from ebuild, if it is not fixed before 6.2.1 release.
You may ask - why I use autoconf-2.61? My answer - it's just default
on my Gentoo system :)
WBR,
Maris.
2006/9/22, Radim Blazek <radim.blazek at gmail.com>:
> On 9/20/06, Markus Neteler <neteler at itc.it> wrote:
> > On Wed, Sep 20, 2006 at 07:03:44PM +0200, Radim Blazek wrote:
> > > Hi.
> > > I cannot create configure with autoconf 2.59, error:
> > > configure.in:362: warning: AC_CANONICAL_HOST invoked multiple times
> > > autoconf/specific.m4:363: AC_CYGWIN is expanded from...
> > > configure.in:362: the top level
> m4_pattern_allow.
> > hi Radim,
> > so far I always used autoconf-2.13 (which still works).
> > Could you try that version as well? Or do you eed to
> > use 2.59?
> Yes, I forgot that it must be 2.13.
> Radim
> > Markus
> > > The reason I need to create configure is that macro
> > > LOC_CHECK_VERSION_INT fails on crosscompiler,
> > > patch is attached.
> > > Radim
> > > _______________________________________________
> > > grass-dev mailing list
> > > grass-dev at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grass-dev
> > Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
> > ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> > MPBA - Predictive Models for Biol. & Environ. Data Analysis
> > Via Sommarive, 18 - 38050 Povo (Trento), Italy
