[GRASS-dev] g.mapsets use of sleep()
Glynn Clements
glynn at gclements.plus.com
Tue Dec 5 19:16:47 EST 2006
Paul Kelly wrote:
> Since $(VASKLIB) was removed from the g.mapsets Makefile I get the
> following error on Windows:
> gcc -L/c/grass/grass6/dist.i686-pc-mingw32/lib -Wl,--export-dynamic,--enable-run
> time-pseudo-reloc -L/c/grass/lib -DPACKAGE=\""grassmods"\" -o /c/grass/
> grass6/dist.i686-pc-mingw32/bin/g.mapsets.exe OBJ.i686-pc-mingw32/main_cmd.o OBJ
> .i686-pc-mingw32/dsply_path.o OBJ.i686-pc-mingw32/dsply_maps.o OBJ.i686-pc-mingw
> 32/get_maps.o /c/grass/grass6/lib/gis/OBJ.i686-pc-mingw32/fmode.o -lgrass_gis -l
> grass_datetime -lxdr -liberty -lws2_32 -lz -lxdr -liberty -lws2_32 -l
> z
> OBJ.i686-pc-mingw32/main_cmd.o(.text+0x427): In function `main':
> c:/grass/grass6/general/g.mapsets/main_cmd.c:128: undefined reference to `sleep'
> collect2: ld returned 1 exit status
> make: *** [/c/grass/grass6/dist.i686-pc-mingw32/bin/g.mapsets.exe] Error 1
> Not at all sure what's the most elegant way of fixing it???
- sprintf (command, "ls -C %s/%s 1>&2", G_gisdbase(), G_location());
+ sprintf (command, "ls -C %s/%s 1>&2 ; sleep 3", G_gisdbase(), G_location());
system (command);
- sleep (3);
OK, so it's not exactly "elegant", but assuming the existence of a
"sleep" command doesn't seem to be any more of a Unix-ism than
assuming the existence of an "ls" command.
Alternatively, use G_sleep() instead:
>From lib/gis/sleep.c:
unsigned int G_sleep (unsigned int seconds)
#ifdef __MINGW32__
/* TODO: no sleep for now */
return 0;
#else /* __MINGW32__ */
return sleep(seconds);
#endif /* __MINGW32__ */
On MinGW, it doesn't actually sleep, but at least you don't get a link
error.
