[GRASS-dev] more NVIZ updates
Helena Mitasova
hmitaso at unity.ncsu.edu
Tue Dec 5 21:01:48 EST 2006
On Dec 5, 2006, at 8:01 PM, Michael Barton wrote:
> On 12/5/06 2:14 AM, "Hamish" <hamish_nospam at yahoo.com> wrote:
> Here are some initial comments and questions before I start working on
> these...
>> some comments/suggestions:
>> * "Visualize->Volumes" is confusing as vector volumes can exist too
>> (watertower, dinosaur)
just a note -
there is a difference - 3D rasters represent trivariate functions
so at each point in 3D space you can have a different value - I think
calling this a volume is quite intuitive
watertower, dinosaur - 3D vector surfaces are quite different - if
you try to represent
it by a volume you would have it filled with just 1 and no-data.
So I don't think that 3D surfaces or 3D vectors should be called
volumes - you essentially have 3D points, lines and areas.
Helena
P.S. I am working on the GRASSbook 3rd edition and I have a list of
terminology
troubles that we have in the manual pages and other documentation.
I will bring it up for discussion when I feel I have most of them to
make the discussion
most efficient and get the big picture too.
> I thought about this too. There is no separate vector volumes panel
> (it
> might be nice though), which is why I went with the simpler
> 'Volumes'. Maybe
> call this one...
> Raster volumes
> Voxels
> Grid 3D volumes
> other?
>> * make the green text of "DRAW", DRAW CURRENT darker. It's hard to
>> read
>> against the grey window background. the NSEW placement arrow isn't as
>> bad, but I'd still make it and the blue text a bit less bright.
> I'll see if I can find a darker color that still looks sort of
> green. The
> idea is to make the "draw" button stand out.
>> * In Vis->Vect points get rid of the empty space when no map is
>> loaded.
>> when a map is loaded, have the thematic controls toggle down
>> instead of
>> always there. aka hide the advanced options so not to overwhelm the
>> user with a 747 cockpit of controls.
> I'd like to have this one close too. I might have figured out how
> to do it
> in the volume control panel, but I'm not sure. I'll see. Same with the
> controls. This is doable but complicated. What makes it worse is
> that the
> code is so old and convoluted.
>> * Rast/Vol panels: don't bother with drop down menus for lists of
>> 2 or 3
>> items (Drawmode, Style, Shading ; Vis type, Shading) You can have all
>> opts on the main panel + a column title without losing much real
>> estate.
>> There's plenty of vertical space in those two panels to play with.
> I agree. I want to keep some consistency among panels, but it is
> good to
> save space--especially with the very large volume panel. I want to
> do some
> other things to tighten this on up if I can.
>> * If you go Vis->Vector pts then Vis->Scaled diff, the points panel
>> doesn't close automatically. Same with a number of other
>> combinations of
>> panels.
> To be frank, I don't know what makes some panels close and others
> stay open.
> The best would be for panels to stay open until a certain cumulative
> vertical size is reached and then close.
>> * fringe: fix the positioning of the fringe corners. Setting the
>> Raster
>> fine resolution to "1" helps a bit. the error depends on that
>> setting.
> This is a togl issue that Bob is working on. Might not be fixable.
>> * default Label text size is very small. Suggest default font size of
>> 17? (16 doesn't exist for me "Cannot Load Font\nTrying default
>> Font")
> Is the same on all systems? I didn't change the defaults because of
> this
> very problem you mention. Any way to find out which sizes might be
> standard
> on most systems?
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
