[GRASS-dev] r.out.gdal2 -> r.out.gdal?
Markus Neteler
neteler at itc.it
Wed Dec 6 04:31:11 EST 2006
I have now:
- renamed the script 'r.out.gdal' to 'r.out.gdal.sh'
- added the 'superseded' therein
- activated the C version of r.out.gdal in the Makefile
This will also solve the problem that the latest QGIS Windows
test built fails on the r.out.gdal[.sh] script as it is
lacking gdal_translate in the install package.
Many thanks to Vytautas V. for writing the C implementation
which is region sensitive and FAST!
For the common r.out.gdal basically nothing changes except
for the region thing and speed.
Markus
On Fri, Dec 01, 2006 at 06:30:30PM +0100, Martin Landa wrote:
> Hi,
> +1 for r.out.gdal2 -> r.out.gdal(C)
> maybe it could be safer to rename the r.out.gdal(script) to
> r.out.gdal2 or r.out.gdal.sh and to add an appropriate warning, e.g.
> WARNING: This module is superseded and will be removed in future
> versions of GRASS. Use r.out.gdal instead.
> Martin
> 2006/12/1, Markus Neteler <neteler at itc.it>:
> >hi,
> >are there objections to rename r.out.gdal2 to
> >r.out.gdal and remove the now obsolete
> >scripts/r.out.gdal/
> >I have used the C version quite a bit successfully.
> >Markus
> >_______________________________________________
> >grass-dev mailing list
> >grass-dev at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass-dev
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
