mkdir function - was: Re: [GRASS-dev] Re: [GRASS-user] 'ARNing: Cannot open driver 'dbf"
Markus Neteler neteler at itc.it
Thu Dec 7 05:47:03 EST 2006
Hamish wrote on 12/07/2006 09:28 AM:
> Hamish:
>>> Can anyone else copy vector maps in windows?
> Markus:
>> in manage/lib/do_copy.c, 'mkdir' is used which IMHO needs a special
>> treatment on Windows. See for example lib/gis/mapset_msc.c
> here I leave this bug- I leave Windows developement as a challenge for
> others to pursue.
There are some candidates for this fix (contains some false positives):
find . -type f -name "*.c" -exec grep -l mkdir {} \;
./general/manage/lib/do_copy.c
./raster/r.li/r.li.daemon/daemon.c
./raster/r.le/r.le.setup/main.c
./raster/r.le/r.le.patch/main.c
./raster/r.le/r.le.pixel/main.c
./lib/init/mke_mapset.c
./lib/init/mke_loc.c
./lib/db/dbmi_driver/d_mkdir.c
./lib/gis/make_mapset.c
./lib/gis/make_loc.c
./lib/gis/mapset_msc.c
./lib/gis/win32_pipes.c
./lib/gis/unix_socks.c
./lib/gis/paths.c
./lib/gis/user_config.c
./lib/raster/io_fifo.c
./lib/g3d/g3dwindowio.c
./gem/reg_entries.c
./gem/actions.c
lib/gis/paths.c
Probably a search/replace of ' mkdir' would do, using G_mkdir() from
./lib/gis/paths.c
? Or we need to modify G_mkdir() to accepts two parameters.
Markus
