[GRASS-dev] Re: North Arrow updates
Thu Dec 7 20:43:45 EST 2006
Bob Covill wrote:
> For me the text color is working.
That's good news.
> The default color is set in panel_main.tcl is where the color is
> currently being set (initialized). For example if you change the value
> for arw_text_clr to 0xFF0000 you should see a red "North".
It's always white for me no matter what I change arw_text_clr to.
I have to call  gsd_colormode(CM_COLOR);  to get the color to change.
(but that then messes up the lighting for everything else)
so more likely:
> > [*] bug #4238 ? I'm not sure if the bug is really in my video card
> > driver, as no one else has reported the same problem AFAIK.
> >   https://intevation.de/rt/webrt?serial_num=4238
> Presumably this will eventually be a user controlled option in the
> arrow panel.
yes.
> Did you intend the text "North" color to be changed differently?
as you've stated above.
Hamish
