[GRASS-dev] Re: winGRASS
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Dec 11 10:24:02 EST 2006
Hello Moritz
I know I got this working but to be honest I'm not completely sure how.
I've made a start on re-doing everything from scratch and making proper
notes now that I know it's possible.
I would say you could try configuring GDAL --without-libtool perhaps.
Also some very promising looking hints and tips on libtool on here:
http://gnuwin32.sourceforge.net/compile.html
Paul
On Mon, 11 Dec 2006, Moritz Lennert wrote:
> Hello Paul,
> (cc'ing this to the list, so that Paul is not alone...)
> On 09/12/06 15:56, Paul Kelly wrote:
>> Hello Moritz
>> On Fri, 8 Dec 2006, Moritz Lennert wrote:
>>> Hello Paul,
>>> I'm finally sitting in front of a Windows computer trying to compile GRASS
>>> myself.
>>> On Thu, November 23, 2006 12:38, Paul Kelly wrote:
>>>> I had a look at that site; certainly lots of useful information on
>>>> building there. E.g. I don't expect they will have the stripped-down XDR
>>>> or GDAL or PROJ, and they were the biggest challenges to build properly
>>>> anyway.
>>> At this stage I just used ./configure;make;make install, just to see
>>> whether everything seems to work.
>>> I imagine I will need to do some more tweaking, would happen to have
>>> recorded your configure settings somewhere ?
>> For the other software, no net yet. Some of it I think I just used the
>> Makefiles as the configure script wasn't working on Windows. But I intend
>> to re-build it all from scratch very soon and will take proper notes then.
> I've tried to build GRASS having just compiled the other libraries with
> configure&make&make install.
> I get the following error:
> c:/Moritz/gdal-cvs-2006.12.07/libgdal.la: file not recognized: File format
> not recognized
> collect2: ld returned 1 exit status
> make[2]: ***
> [/c/moritz/grass6/dist.i686-pc-mingw32/lib/libgrass_gproj.6.3.cvs.dll] Error
> 1
> and
> not recognized
> make[3]: ***
> [/c/moritz/grass6/dist.i686-pc-mingw32/lib/libgrass_vect.6.3.cvs.dll] Error 1
> which then obviously leads to many errors afterwards.
> I have attached the entire make log and the libgdal.la file.
> Any ideas of what is wrong with the .la file ?
> Also, I've seen some debate on cross-compiling lately. If this is reasonably
> easy, it would make life easier for me as I would not have to wait for my
> colleague's windows machine to be free...
> Moritz
