[GRASS-dev] v.to.db option=slope
Jachym Cepicky
jachym.cepicky at centrum.cz
Tue Dec 12 02:28:55 EST 2006
hallo,
On Mon, Dec 11, 2006 at 07:01:21PM +0000, Paul Kelly wrote:
> Hello Jachym
> Just a little comment below:
> On Mon, 11 Dec 2006, Jachym Cepicky wrote:
> >On Mon, Dec 11, 2006 at 06:58:36PM +0100, Markus Neteler wrote:
> >>On Mon, Dec 11, 2006 at 06:53:57PM +0100, Jachym Cepicky wrote:
> >>>hi,
> >>>since nobody really complained, I commited the patch. v.to.db has new
> >>>option "slope" now
> >>hi jachym,
> >>does it now work for LatLong? I guess I overlooked some email.
> >no, it does not :-( it does not even work with option=length, because of
> >Vect_cidx_get_num_unique_cats_by_index ( &Map,
> >Vect_cidx_get_field_index(&Map, options.field ) );
> >in main.c returns 1634887471 of unique cats by index and v.to.db ends up
> >with G_calloc error: could not allocat memory.
> >I have no clue, how to fix this bug.
> I (maybe others) interpreted this as you admitting that the patch was not
> yet ready/good enough to commit to CVS! So maybe that's why nobody
> complained - Is it true that wrong results will be given in a lat/long
> location with no warning? If so, then something should be changed.
> If not, and I've misunderstood, then it's all OK!
> Paul
Slope is calculated with line lenght. Calculating line length on
lat/long location does not work either. This patch adds new funtionality
and (should) does not break old ones. I tryed this in GRASS 6.2 and
calculating line length on lat/long location does not work there too.
So, as I got mostly positive feedback and as I did not break any
funtionality, I commited the patch.
I also tryed to describe, why this does not work on lat/long locations.
Sorry, I was not able to find out, where exactly the problem is. I
guess, some variable is not initialized.
If I should not commit the patch, because of this all, I'm sorry and
will remove this patch from cvs.
I'll fill the bug tracker for the length issue.
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
OFFICE:
Department of Geoinformation Technologies
Zemedelska 3
613 00, Brno
Czech Republick
e-mail: xcepicky at node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061212/b9be0c7b/attachment.bin
