[GRASS-dev] Re: winGRASS
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Dec 12 16:37:08 EST 2006
Oh and in case anybody is trying this, you won't get too far with the
Windows startup without changing the path to WINGISBASE in grass63.bat
(the startup file) to have Windows-style backslash-\ directory separator
characters. Can't seem to get the Makefile to put these in but I guess
I'll get it working eventually.
On Tue, 12 Dec 2006, Paul Kelly wrote:
> Hello Moritz
> I've got a bit further with documenting what I was doing. See attached for
> some of my notes. Mostly on compiling the accompanying libraries GRASS
> absolutely needs:
> XDR
> Zlib
> libpng
> PROJ.4
> GDAL
> I put these into a gzipped tar file in case anybody would like to get started
> quickly - in this case you would just need Msys,Mingw with bison and flex.
> Everything else included in here:
> http://www.stjohnspoint.co.uk/grass/wingrass-extralibs.tar.gz
> and then the prefix where you untar that file you will need to supply to the
> GRASS configure as:
> --with-includes=prefix --with-libs=prefix
> FWIW my configure line was:
> ./configure --prefix=c:/grass --bindir=c:/grass/bin \
> --with-includes=/c/grass/forgrass/include \
> --with-libs=/c/grass/forgrass/lib --with-cxx --without-jpeg --without-tiff \
> --without-postgres --with-opengl=windows --without-fftw --without-x \
> --enable-x11=no --enable-shared=yes --with-tcltk-includes=/c/tcl/include \
> --with-tcltk-libs=/c/tcl/bin
> After compiling you should copy libxdr.dll, libproj.dll, libpng.dll,
> libgdal-1.dll and libz.dll.1.2.3 into the GRASS lib directory and all the
> GDAL and PROJ .exe files in the bin directory into the GRASS bin directory,
> and then you have a more or less self-contained GRASS distribution.
> I also installed Activestate Tcl/Tk 8.4.13 (in c:\tcl).
> I could make a binary distribution that sort of works OK to a certain extent
> without having Msys/Mingw installed, only thing is I want to wait until Nviz
> is working again on Windows as it was up to yesterday. The problem is
> starting it from a script. Scripts are very problematic (and of course only
> possible at all if you have Msys installed) because of the way Msys handles
> Windows paths.
> If you have Msys and Mingw installed, putting their bin directories in the
> PATH makes things in general run more smoothly, but of course that's
> cheating!
> Paul
