[GRASS-dev] v.edit updates
Michael Barton
michael.barton at asu.edu
Wed Dec 13 12:15:19 EST 2006
Jachym,
Because we need to have a digitizing tool that works without x11, I'm in
favor of moving ahead with v.edit since it is by far the most advanced
attempt to get this rolling so far.
I haven't had time to review and test it however.
Michael
On 12/13/06 3:17 AM, "Jachym Cepicky" <jachym.cepicky at centrum.cz> wrote:
> Hallo,
> since nobody answared, I suppose there nobody had enough time to check
> the patches.
> Before I move with further development, I would like to hear from the
> GRASS-core developers, that this changes are all right and worth to be
> committed to cvs.
> I did not commit this changes yet, because of they are changing behavior
> and features of v.edit significantly.
> Removed options:
> type - there is no need to define type of the vector input feature,
> this can be done using other methods (grass ascii format)
> values - all database updates should be done via db.* commands
> Changes options:
> coords - coords were used for data inputs. But it could come to
> maximum length of a line limit.
> coords option is used for feature identification, not for
> data input
> action->tool - IMHO "tool" does fit idea of the option better, than
> action
> tools: merge - removed
> new tools introduced
> Added options:
> to - moving to coordinates
> at - breaking/spliting at this coordinates
> bbox - for bounding box feature selection
> about - (not added yet) for moving features +- map units
> How to test this:
> This commands should give you impression about how v.edit currently
> works:
> # copy soils map
> g.copy vect=soils,tmp --o
> d.mon x0
> d.vect tmp
> # add new line the soils map
> echo "L 2 1
> 593229.5625 4917307.3125
> 606824.0625 4926102
> 1 60" | v.edit map=tmp tool=add
> v.build tmp
> echo "insert into tmp (cat, label) values (60,'road');"|db.execute
> d.redraw
> # remove feature defined by coordinates
> v.edit map=tmp tool=delete coords=593229.5625,4917307.3125
> d.redraw # line should be removed
> # remove feature defined by category
> v.edit map=tmp tool=delete cat=13
> d.redraw # big soil area on south should be removed
> # remove featuers defined by bounding box
> d.graph -m color=0:255:0 << EOF
> width 4
> polyline
> 602203.125 4918112.25
> 602203.125 4924402.6875
> 604319.8125 4924402.6875
> 604319.8125 4918112.25
> EOF
> v.edit map=tmp tool=delete bbox=602203.125,4918112.25,604319.8125,4924402.6875
> d.redraw
> I prepared new patch (attached). If there will be no provisos, I would
> like to add this to cvs soon and continue with the development.
> Thank you
> Jachym
> On Tue, Dec 12, 2006 at 02:41:42PM +0100, Jachym Cepicky wrote:
>> Hallo,
>> according to suggested funtion of v.edit [1], I started to work on
>> v.edit module.
>> I prepared patch for this and it would be great, if anybody could look
>> at it and say, if it is worth to commit to cvs.
>> Currently, only tools "delete" and "add" are supported. But they cand be
>> used on slightly different way:
>> With this patch, v.edit no longer accepts input in form of comma
>> separated list of coordinates, but it reads input (tools "create" and
>> "add") from stdin or from ASCII file. I used a2b.c file from v.in.ascii
>> for this purpose. Currently, it does not accept header of the vector
>> file, so v.out.ascii vect|v.edit tool=add would not work.
>> For "tool=remove", new ways for feature definition are defined:
>> coords=x,y - remove feature, which can be found on coordinates x,y
>> cats=3,4 - remove reature with category 3 or 4
>> bbox=x1,y1,x2,y2 - remove features in bounding box
>> If everything will be all right, I'll continue on v.edit with moving and
>> spliting tools
>> Looking forward to your feedback
>> Jachym
>> [1] http://grass.gdf-hannover.de/wiki/GRASS_Digitizing_tool#v.edit
>> Jachym Cepicky
>> e-mail: jachym.cepicky at centrum.cz
>> URL: http://les-ejk.cz
>> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
>> OFFICE:
>> Department of Geoinformation Technologies
>> Zemedelska 3
>> 613 00, Brno
>> Czech Republick
>> e-mail: xcepicky at node.mendelu.cz
>> URL: http://mapserver.mendelu.cz
>> Tel.: +420 545 134 514
>> Index: vector/v.edit/a2b.c
>> RCS file: vector/v.edit/a2b.c
>> diff -N vector/v.edit/a2b.c
>> --- /dev/null 1 Jan 1970 00:00:00 -0000
>> +++ vector/v.edit/a2b.c 12 Dec 2006 13:29:22 -0000
>> @@ -0,0 +1,171 @@
>> + * This file has been adopted from v.in.ascii code
>> +#include <stdio.h>
>> +#include <string.h>
>> +#include <grass/gis.h>
>> +#include <grass/Vect.h>
>> +#include <grass/glocale.h>
>> +#include "global.h"
>> +#define BUFFSIZE 128
>> +int asc_to_bin(FILE *ascii , struct Map_info *Map)
>> + char ctype ;
>> + char buff[BUFFSIZE];
>> + double *xarray ;
>> + double *yarray ;
>> + double *zarray ;
>> + double *x, *y, *z;
>> + int i, n_points, n_coors, n_cats ;
>> + int type;
>> + int alloc_points ;
>> + int end_of_file ;
>> + struct line_pnts *Points;
>> + struct line_cats *Cats;
>> + int catn;
>> + int cat;
>> + /* Must always use this to create an initialized line_pnts structure */
>> + Points = Vect_new_line_struct ();
>> + Cats = Vect_new_cats_struct ();
>> + end_of_file = 0 ;
>> + /*alloc_points = 1000 ; */
>> + alloc_points = 1;
>> + xarray = (double *) G_calloc(alloc_points, sizeof(double)) ;
>> + yarray = (double *) G_calloc(alloc_points, sizeof(double)) ;
>> + zarray = (double *) G_calloc(alloc_points, sizeof(double)) ;
>> + while( G_getl2(buff,BUFFSIZE-1,ascii) != 0 )
>> + n_cats=0;
>> + if (buff[0] == '\0') {
>> + G_debug(3, "a2b: skipping blank line");
>> + continue;
>> + if ( sscanf(buff, "%1c%d%d", &ctype, &n_coors, &n_cats) < 2 ||
>> n_coors < 0 || n_cats < 0 ) {
>> + if (ctype == '#') {
>> + G_debug(2, "a2b: skipping commented line");
>> + continue;
>> + G_warning (_("Error reading ascii file <%s>"), buff) ;
>> + return 0;
>> + G_debug(2, "a2b: Skipping commented line");
>> + continue;
>> + switch(ctype){
>> + case 'A':
>> + type = GV_BOUNDARY ;
>> + break ;
>> + case 'B':
>> + break ;
>> + case 'C':
>> + type = GV_CENTROID ;
>> + break ;
>> + case 'L':
>> + type = GV_LINE ;
>> + break ;
>> + case 'P':
>> + type = GV_POINT ;
>> + break ;
>> + case 'F':
>> + type = GV_FACE ;
>> + break ;
>> + case 'K':
>> + type = GV_KERNEL ;
>> + break ;
>> + case 'a':
>> + case 'b':
>> + case 'c':
>> + case 'l':
>> + case 'p':
>> + type = 0; /* dead -> ignore */
>> + break;
>> + default:
>> + G_warning (_("Error reading ascii file: <%s>"), buff) ;
>> + return 0;
>> + G_debug(5, "feature type = %d", type);
>> + n_points = 0 ;
>> + x = xarray ;
>> + y = yarray ;
>> + z = zarray ;
>> + /* Collect the points */
>> + for( i=0; i<n_coors; i++)
>> + if ( G_getl2(buff,BUFFSIZE-1,ascii) == 0 ) {
>> + G_warning (_("End of ascii file reached before end of coordinates")) ;
>> + return 0;
>> + G_debug(3, "a2b: skipping blank line while reading vertices");
>> + i--;
>> + continue;
>> + *z=0;
>> + if ( sscanf(buff, "%lf%lf%lf", x, y, z) < 2 ) {
>> + return 0;
>> + G_debug( 5, "coor in: %s -> x = %f y = %f z = %f", G_chop(buff), *x,
>> *y, *z);
>> + n_points++;
>> + x++;
>> + y++;
>> + z++;
>> + if (n_points >= alloc_points)
>> + alloc_points = n_points + 1000 ;
>> + xarray = (double *) G_realloc((void *)xarray, alloc_points *
>> sizeof(double) );
>> + yarray = (double *) G_realloc((void *)yarray, alloc_points *
>> sizeof(double) );
>> + zarray = (double *) G_realloc((void *)zarray, alloc_points *
>> sizeof(double) );
>> + x = xarray + n_points ;
>> + y = yarray + n_points ;
>> + z = zarray + n_points ;
>> + /* Collect the cats */
>> + for( i=0; i<n_cats; i++)
>> + G_warning (_("End of ascii file reached before end of categories.")) ;
>> + return 0;
>> + G_debug(3, "a2b: skipping blank line while reading category info");
>> + i--;
>> + continue;
>> + if ( sscanf(buff, "%u%u", &catn, &cat) != 2 ) {
>> + G_warning (_("Error reading categories: <%s>"), buff) ;
>> + return 0;
>> + Vect_cat_set ( Cats, catn, cat );
>> + /* Allocation is handled for line_pnts */
>> + if (0 > Vect_copy_xyz_to_pnts (Points, xarray, yarray, zarray,
>> n_points))
>> + G_fatal_error(_("Out of memory"));
>> + if ( type > 0 )
>> + Vect_write_line ( Map, type, Points, Cats );
>> + Vect_reset_cats ( Cats );
>> + return 0;
>> Index: vector/v.edit/args.c
>> RCS file: /grassrepository/grass6/vector/v.edit/args.c,v
>> retrieving revision 1.6
>> diff -u -r1.6 args.c
>> --- vector/v.edit/args.c 7 Jun 2006 19:16:16 -0000 1.6
>> +++ vector/v.edit/args.c 12 Dec 2006 13:29:22 -0000
>> @@ -4,48 +4,74 @@
>> map_opt = G_define_standard_option(G_OPT_V_MAP);
>> - act_opt = G_define_option();
>> - act_opt->key = "action";
>> - act_opt->type = TYPE_STRING;
>> - act_opt->required = YES;
>> - act_opt->multiple = NO;
>> - act_opt->description = _("The edit action to take.");
>> - act_opt->options = "create,add,delete,move,merge";
>> - typ_opt = G_define_standard_option(G_OPT_V_TYPE);
>> - typ_opt->required = NO;
>> - typ_opt->description = _("Select type. Required for add action.");
>> - typ_opt->options = "point,line,area,centroid,boundary";
>> - typ_opt->answer = "point";
>> + tool_opt = G_define_option();
>> + tool_opt->key = "tool";
>> + tool_opt->type = TYPE_STRING;
>> + tool_opt->required = YES;
>> + tool_opt->multiple = NO;
>> + tool_opt->description = _("The edit tool to take.\n"
>> + "\t\tcreate - Create new vector file\n"
>> + "\t\tadd - Add new vector feature to
>> existing vector file\n"
>> + "\t\tdelete - Delete feature from vector
>> file\n"
>> + "\t\tmove - Move feature in vector file\n"
>> + "\t\tvertex - Move just only vertex\n"
>> + "\t\tbreak - Add new vertex to existing vector
>> line\n"
>> + "\t\tsplit - Split line into two separate
>> lines");
>> + tool_opt->options = "create,add,delete,move,vertex,break,split";
>> + input_opt = G_define_option();
>> + input_opt->key = "input";
>> + input_opt->type = TYPE_STRING;
>> + input_opt->required = NO;
>> + input_opt->multiple = NO;
>> + input_opt->description = _("ASCII file to be converted to binary vector
>> file, if not given reads from standard input");
>> cat_opt = G_define_standard_option(G_OPT_V_CATS);
>> cat_opt->required = NO;
>> - pnt_opt = G_define_option();
>> - pnt_opt->key = "coords";
>> - pnt_opt->key_desc = "x,y";
>> - pnt_opt->type = TYPE_DOUBLE;
>> - pnt_opt->required = NO;
>> - pnt_opt->multiple = YES;
>> - pnt_opt->description = _("An x,y list of points. Required for add and
>> move actions.");
>> - val_opt = G_define_option();
>> - val_opt->key = "values";
>> - val_opt->type = TYPE_STRING;
>> - val_opt->required = NO;
>> - val_opt->multiple = NO;
>> - val_opt->description = _("A comma-separated list of attr=val pairs.");
>> + coord_opt = G_define_option();
>> + coord_opt->key = "coords";
>> + coord_opt->key_desc = "x,y";
>> + coord_opt->type = TYPE_DOUBLE;
>> + coord_opt->required = NO;
>> + coord_opt->multiple = YES;
>> + coord_opt->description = _("An x,y list of points. Required for add and
>> move actions.");
>> + to_opt = G_define_option();
>> + to_opt->key = "to";
>> + to_opt->key_desc = "x,y";
>> + to_opt->type = TYPE_DOUBLE;
>> + to_opt->required = NO;
>> + to_opt->multiple = NO;
>> + to_opt->description = _("An x,y location of selected feature");
>> + at_opt = G_define_option();
>> + at_opt->key = "at";
>> + at_opt->key_desc = "x,y";
>> + at_opt->type = TYPE_DOUBLE;
>> + at_opt->required = NO;
>> + at_opt->multiple = NO;
>> + at_opt->description = _("An x,y location of breaking feature");
>> + bbox_opt = G_define_option();
>> + bbox_opt->key = "bbox";
>> + bbox_opt->key_desc = "x1,y1,x2,y2";
>> + bbox_opt->type = TYPE_DOUBLE;
>> + bbox_opt->required = NO;
>> + bbox_opt->multiple = NO;
>> + bbox_opt->description = _("Bounding box of selected feature");
>> + snap_opt = G_define_option();
>> + snap_opt->key = "snap";
>> + snap_opt->type = TYPE_DOUBLE;
>> + snap_opt->required = NO;
>> + snap_opt->multiple = NO;
>> + snap_opt->description = _("Object points will snap to existing points
>> within snap units.");
>> + snap_opt->answer = "5.0";
>> fld_opt = G_define_standard_option(G_OPT_V_FIELD);
>> - snp_opt = G_define_option();
>> - snp_opt->key = "snap";
>> - snp_opt->type = TYPE_DOUBLE;
>> - snp_opt->required = NO;
>> - snp_opt->multiple = NO;
>> - snp_opt->description = _("Object points will snap to existing points
>> - snp_opt->answer = "5.0";
>> t_flg = G_define_flag();
>> t_flg->key = 't';
>> t_flg->description = _("Do not use topology.");
>> @@ -62,59 +88,136 @@
>> c_flg->key = 'c';
>> c_flg->description = _("Do not close boundaries");
>> + n_flg = G_define_flag();
>> + n_flg->key = 'n';
>> + n_flg->description = _("Don't expect a header");
>> if(G_parser(argc, argv))
>> return 0;
>> /* check that the given arguments makes sense together*/
>> /** @todo check for incorrect extra parameters */
>> - if(strcmp(act_opt->answer, "create")==0) { /* create requires nothing
>> extra*/
>> + if ( input_opt->answer != NULL ) {
>> + if ( (ascii = fopen ( input_opt->answer, "r" ) ) == NULL )
>> + G_warning(_("Could not open ascii file <%s>"),
>> input_opt->answer);
>> + G_usage();
>> + } else {
>> + ascii = stdin;
>> + /* check for coordinate param */
>> + if (coord_opt->answers != NULL) {
>> + int i = 0;
>> + for (i = 0; coord_opt->answers[i]; i ++)
>> + if (i%2 != 0) {
>> + G_warning(_("Number of coordinates must be odd number"));
>> + G_usage();
>> + return 0;
>> + /* check for bbox param */
>> + if (bbox_opt->answers != NULL) {
>> + int i = 0;
>> + for (i = 0; bbox_opt->answers[i]; i ++)
>> + if (i%2 != 0) {
>> + G_usage();
>> + return 0;
>> + if(strcmp(tool_opt->answer, "create")==0) { /* create requires nothing
>> extra*/
>> action_mode = MODE_CREATE;
>> return 1;
>> - snap = atof(snp_opt->answer);
>> - if(strcmp(act_opt->answer, "add")==0) { /* add requires a points
>> argument */
>> + if(strcmp(tool_opt->answer, "add")==0) { /* add requires a points
>> argument */
>> action_mode = MODE_ADD;
>> - if(pnt_opt->answers == NULL) {
>> - help(_("Required parameter <points> not set"));
>> + return 1;
>> + else if(strcmp(tool_opt->answer, "delete")==0) { /* del requires a cats
>> or or bbox or coords*/
>> + action_mode = MODE_DEL;
>> + if((cat_opt->answers == NULL) &&
>> + (coord_opt->answers == NULL) &&
>> + (bbox_opt->answers == NULL)) {
>> + G_warning(_("At least one from <%s> must be specified"),"cats, coords,
>> bbox");
>> + G_usage();
>> return 0;
>> return 1;
>> - else if(strcmp(act_opt->answer, "delete")==0) { /* del requires a cats
>> - action_mode = MODE_DEL;
>> - if(cat_opt->answers == NULL) {
>> - help(_("Required parameter <cats> not set"));
>> + else if(strcmp(tool_opt->answer, "move")==0) { /* move requires coords
>> or cats arguments */
>> + action_mode = MODE_MOVE;
>> + if(to_opt->answers == NULL) {
>> + G_warning(_("For <%s> operation, option <%s> must be
>> set"),"move","to");
>> + G_usage();
>> + return 0;
>> + if((coord_opt->answers == NULL) &&
>> + (cat_opt->answers == NULL) &&
>> bbox");
>> + G_usage();
>> return 0;
>> return 1;
>> - else if(strcmp(act_opt->answer, "move")==0) { /* move requires points
>> and cats arguments */
>> - action_mode = MODE_ADD;
>> - if((pnt_opt->answers == NULL)||(cat_opt->answers == NULL)) {
>> - help(_("Both parameters <points> and <cats> are required."));
>> + else if(strcmp(tool_opt->answer, "vertex")==0) { /* move vertex requires
>> a coord and to options */
>> + action_mode = MODE_VERTEX;
>> + if(coord_opt->answers == NULL) {
>> + G_warning(_("Required parameter <coords> not set"));
>> + G_usage();
>> + return 0;
>> + G_warning(_("Required parameter <to> not set"));
>> + G_usage();
>> return 0;
>> return 1;
>> - else if(strcmp(act_opt->answer, "merge")==0) { /* merge requires a cats
>> argument */
>> + else if(strcmp(tool_opt->answer, "break")==0) { /* break line requires a
>> coord and at options */
>> + action_mode = MODE_BREAK;
>> + G_usage();
>> + return 0;
>> + if(at_opt->answers == NULL) {
>> + G_warning(_("Required parameter <at> not set"));
>> + G_usage();
>> return 0;
>> return 1;
>> + else if(strcmp(tool_opt->answer, "split")==0) { /* split line requires a
>> + action_mode = MODE_SPLIT;
>> + G_usage();
>> + return 0;
>> + G_usage();
>> + return 0;
>> + return 1;
>> else {
>> - help(_("This should never happen."));
>> + G_warning(_("Operation <%s> not implemented."),tool_opt->answer);
>> + G_usage();
>> return 0;
>> -void help(const char *msg)
>> - G_message("\nERROR: %s\n\n", msg);
>> - G_usage();
>> Index: vector/v.edit/del.c
>> RCS file: /grassrepository/grass6/vector/v.edit/del.c,v
>> retrieving revision 1.2
>> diff -u -r1.2 del.c
>> --- vector/v.edit/del.c 6 Oct 2006 06:47:56 -0000 1.2
>> +++ vector/v.edit/del.c 12 Dec 2006 13:29:23 -0000
>> @@ -2,45 +2,151 @@
>> int do_del(struct Map_info *Map)
>> - int i;
>> + int res = 0;
>> + /* cats or coord or bbox */
>> + if(cat_opt->answer != NULL) {
>> + res = delete_categories(Map);
>> + else if (coord_opt->answer != NULL) {
>> + res = delete_coordinates(Map);
>> + else if (bbox_opt->answer != NULL) {
>> + res = delete_bbox(Map);
>> + else {
>> + /* this case should not happen, see args.c for details */
>> + G_warning("cats, coord or bbox must be specified");
>> +int delete_bbox(struct Map_info *Map)
>> + double x1,y1,x2,y2;
>> + BOUND_BOX bbox;
>> + BOUND_BOX feature_bbox;
>> + int cat, ret, type, i;
>> + struct ilist *List;
>> + SPATIAL_INDEX si;
>> + int removed = 0;
>> + /* bounding box */
>> + x1 = atof(bbox_opt->answers[0]);
>> + y1 = atof(bbox_opt->answers[1]);
>> + x2 = atof(bbox_opt->answers[2]);
>> + y2 = atof(bbox_opt->answers[3]);
>> + bbox.N = y1 < y2 ? y2 : y1;
>> + bbox.S = y1 < y2 ? y1 : y2;
>> + bbox.W = x1 < x2 ? x1 : x2;
>> + bbox.E = x1 < x2 ? x2 : x1;
>> + bbox.T = 0.0;
>> + bbox.B = 0.0;
>> + Points = Vect_new_line_struct();
>> + Cats = Vect_new_cats_struct();
>> + List = Vect_new_list ();
>> + /* get lines number */
>> + Vect_select_lines_by_box ( Map, &bbox, GV_POINTS | GV_LINES |
>> GV_BOUNDARY | GV_CENTROID, List );
>> + G_debug ( 1, " %d lines selected by box", List->n_values );
>> + for ( i = 0; i < List->n_values; i++) {
>> + type = Vect_read_line(Map, Points, Cats, List->value[i]);
>> + G_debug(2, "Deleting type [%d] number [%d]", type, List->value[i]);
>> + Vect_delete_line(Map, List->value[i]);
>> + removed++;
>> + /* attr_del(Map, layer, cat);*/
>> + G_message(_("%d features deleted"), removed);
>> + return 1;
>> +int delete_coordinates(struct Map_info *Map)
>> + double east, north;
>> + int line;
>> + double maxdist = 0.5;
>> + char buff[16] = "";
>> + int type;
>> + int cat;
>> + int field=atoi(fld_opt->answer);
>> + int removed = 0;
>> + east = atof(coord_opt->answers[0]);
>> + north = atof(coord_opt->answers[1]);
>> + line = Vect_find_line(Map, east, north, 0.0, GV_POINT | GV_CENTROID,
>> maxdist, 0, 0);
>> + if (line == 0)
>> + line = Vect_find_line(Map, east, north, 0.0, GV_LINE | GV_BOUNDARY |
>> GV_FACE, maxdist, 0, 0);
>> + G_debug (2, "line = %d", line);
>> + if (line == 0) {
>> + G_warning(_("Nothing Found."));
>> + return 0;
>> + else {
>> + type = Vect_read_line(Map, Points, Cats, line);
>> + if ((cat = Vect_get_line_cat(Map, line, field )) > 0)
>> + sprintf(buff,_("category [%d]"),cat);
>> + G_debug(2, "Deleting type [%d] number [%d] %s", type, line, buff);
>> + Vect_delete_line(Map, line);
>> + removed++;
>> + return 1;
>> +int delete_categories(struct Map_info *Map)
>> struct cat_list * cl;
>> int layer=atoi(fld_opt->answer);
>> + int i, removed=0;
>> - G_debug(1,"layer = %d",layer);
>> - if(cat_opt->answer=NULL) {
>> - cats = coords_catlist(Map);
>> cl = Vect_new_cat_list();
>> Vect_str_to_cat_list(cat_opt->answer, cl);
>> + G_debug(1,"layer = %d",layer);
>> for(i=0;i<cl->n_ranges;i++) {
>> int cat, type, id, ret;
>> G_debug(1, "cl->min[%d]=%d, cl->max[%d]=%d, layer=%d",
>> i, cl->min[i], i, cl->max[i], cl->field);
>> for(cat=cl->min[i]; cat <= cl->max[i]; cat++) {
>> - ret = Vect_cidx_find_next(Map, layer, cat, GV_POINTS|GV_LINES,
>> + ret = Vect_cidx_find_next(Map, layer, cat, GV_POINTS|GV_LINES |
>> 0, &type, &id);
>> G_debug(1, "ret=%d", ret);
>> if(ret<0) continue;
>> - G_debug(1, "Found something to delete: id=%d, type=%d",id,type);
>> - if(type==GV_CENTROID) {
>> - int area;
>> - double x,y;
>> - Vect_get_node_coor(Map, id, &x, &y, NULL);
>> - area = Vect_find_area(Map, x, y);
>> - G_debug(1, "Deleteing area %d: id=%d, area=%d",cat,id,area);
>> -/* Vect_delete_line(Map, id); */
>> -/* Vect_delete_line(Map, area); */
>> - attr_del(Map, layer, cat);
>> - else {
>> + G_debug(2,"Deleting type [%d] number [%d] cat [%d]", type, id,
>> cat);
>> + Vect_delete_line(Map, id);
>> + removed ++;
>> return 1;
>> Index: vector/v.edit/global.h
>> RCS file: /grassrepository/grass6/vector/v.edit/global.h,v
>> diff -u -r1.6 global.h
>> --- vector/v.edit/global.h 7 Jun 2006 19:16:16 -0000 1.6
>> +++ vector/v.edit/global.h 12 Dec 2006 13:29:23 -0000
>> @@ -18,15 +18,18 @@
>> MODE_ADD,
>> MODE_DEL,
>> MODE_MOVE,
>> - MODE_MERGE
>> + MODE_VERTEX,
>> + MODE_SPLIT,
>> + MODE_BREAK
>> -void help(const char *msg);
>> int parser(int argc, char*argv[]);
>> -int do_add(struct Map_info *Map);
>> +int asc_to_bin(FILE *, struct Map_info *);
>> int do_del(struct Map_info *Map);
>> +int delete_categories(struct Map_info *Map);
>> +int delete_coordinates(struct Map_info *Map);
>> +int delete_bbox(struct Map_info *Map);
>> void cat_max_set ( int field, int cat);
>> int cat_max_get ( int field );
>> @@ -37,11 +40,12 @@
>> int attr_edit(struct Map_info *Map, int field, int cat, const char *vals);
>> int attr_del(struct Map_info *Map, int field, int cat);
>> -global struct Option *map_opt, *act_opt, *typ_opt, *cat_opt, *pnt_opt,
>> *fld_opt, *val_opt, *snp_opt;
>> -global struct Flag *n_flg, *t_flg, *d_flg, *b_flg, *c_flg;
>> +global struct Option *input_opt, *map_opt, *tool_opt, *coord_opt, *cat_opt,
>> *to_opt, *at_opt, *bbox_opt, *snap_opt, *fld_opt;
>> +global struct Flag *n_flg, *t_flg, *d_flg, *b_flg, *c_flg, *n_flg;
>> global struct GModule *module;
>> global struct Map_info Map;
>> global enum mode action_mode;
>> global char *mapset;
>> -global double snap;
>> +global FILE *ascii;
>> #endif
>> Index: vector/v.edit/main.c
>> RCS file: /grassrepository/grass6/vector/v.edit/main.c,v
>> retrieving revision 1.9
>> diff -u -r1.9 main.c
>> --- vector/v.edit/main.c 6 Oct 2006 06:47:56 -0000 1.9
>> +++ vector/v.edit/main.c 12 Dec 2006 13:29:23 -0000
>> @@ -21,6 +21,7 @@
>> #define MAIN
>> #include "global.h"
>> /* static int error_routine(const char*msg, int fatal); */
>> int main (int argc, char *argv[])
>> @@ -56,7 +57,6 @@
>> else {
>> /* Vect_set_open_level(2); */
>> - G_message(_("Reading vector file ..."));
>> Vect_open_update (&Map, map_opt->answer, mapset);
>> /* Vect_set_category_index_update ( &Map ); */
>> @@ -66,7 +66,8 @@
>> switch(action_mode) {
>> case MODE_ADD:
>> - ret = do_add(&Map);
>> + G_message(_("Adding new features to vector file ..."));
>> + ret = asc_to_bin(ascii, &Map) ;
>> break;
>> case MODE_DEL:
>> ret = do_del(&Map);
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
