[GRASS-dev] Re: mkdir function
Glynn Clements
glynn at gclements.plus.com
Wed Dec 13 17:58:22 EST 2006
Glynn Clements wrote:
> I've attached an updated patch; apart from eliminating
> the compilation errors, it eliminates the warnings arising from the
> addition of G_lstat().
However, photo.elev fails to compile due to a conflicting use of
"stat" in elev.h.
In retrospect, this is probably sufficient (and less problematic):
--- include/gisdefs.h 13 Dec 2006 16:48:41 -0000 1.74
+++ include/gisdefs.h 13 Dec 2006 22:57:17 -0000
@@ -870,6 +870,7 @@
int G_is_dirsep(char);
char *G_convert_dirseps_to_host(char *);
char *G_convert_dirseps_from_host(char *);
+struct stat;
int G_lstat(const char *, struct stat *);
/* percent.c */
