[GRASS-dev] updates to grass startup
Thu Dec 14 05:57:17 EST 2006
Hamish wrote:
> > > now locations and mapsets are not sorted in alphabetical order.
> > I wonder what changed this? Need to look back at the code.
> maybe this?
> CVS log for grass6/lib/init/gis_set.tcl
> Revision 1.41 / (as text) / (view) - annotate - [select for diffs] , Wed Dec 6 00:01:53 2006 UTC (8 days, 6 hours ago) by michael
> Branch: MAIN
> Changes since 1.40: +18 -26 lines
> Replace exec ls with pure TclTk (glob, etc) for Windows compatibility.
> Perhaps glob gives raw order?
According to the glob(n) manpage:
       The glob command differs from csh globbing in two ways.  First, it does
       not  sort  its  result list (use the lsort command if you want the list
       sorted). [snip]
