[GRASS-dev] Re: mkdir function
Hamish
hamish_nospam at yahoo.com
Fri Dec 15 01:30:39 EST 2006
> > > lib/raster/io_fifo.c
> > Can't we just kill this? I don't even know if it still works, given
> > that almost no-one actually uses --enable-fifo.
> > In any case, I doubt that file will work on Windows.
> If we don't need it, let's remove it. Unused code is only
> confusing.
just for curiosity, what's the (dis)advantage of using FIFO vs sockets?
Hamish
