[GRASS-dev] Re: winGRASS
Markus Neteler
neteler at itc.it
Fri Dec 15 04:18:37 EST 2006
On Fri, Dec 15, 2006 at 09:14:19AM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > On Thu, Dec 14, 2006 at 06:12:35PM +0100, Moritz Lennert wrote:
> > > (most of the following with sys/wait.h: No such file or directory)
> > I have conditionalized sys/wait.h in all files.
> I can't see how that will help, as the files in question use fork()
> and wait(), neither of which exist under MinGW.
I took that from an existing GRASS module, it was not my
invention :-)
At least it is now identical everywhere (lib/gis/ I left untouched).
If you have a suggestion to get it right, I can make a
new round to fix it.
> As i.ortho.photo also requires an X monitor, it isn't likely to run
> natively on Windows in the foreseeable future.
I understood that Brad is working on that. Maybe, integrated with
v.edit, this can be solved.
Markus
