[GRASS-dev] [bug #5391] (grass) Add dual-arch static copy of
portable.h
Request Tracker
grass-bugs at intevation.de
Fri Dec 15 10:16:20 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5391
Subject: Add dual-arch static copy of portable.h
Platform: Mac OSX
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 6.3.CVS.20061202
Another one for building Mac OS X universal binaries. lib/vector/diglib/portable.h for universal OS
X. I've simply taken a Pac PPC and Intel copy and merged them together. The correct version is
chosen by a #ifdef based on a Mac standard __LITTLE_ENDIAN__ macro. This will work in an all-at-
once universal build (specifying ppc and intel architectures on the same compile command) since
internally they are compiled separately, then joined, and so headers are processed for each arch.
I didn't work out makefile changes, but it would be something like the MINGW ifdef in the diglib
makefile. This would also need a platform.make setting to say it's a Mac build, and configure logic
to set it.
suggested lib/vector/diglib/portable/universal-macosx-gcc.h to be copied to portable.h at build
time:
/* Architecture: universal-apple-darwin */
/* Native machine sizes */
#define NATIVE_DOUBLE 8
#define NATIVE_FLOAT 4
#define NATIVE_LONG 4
#define NATIVE_INT 4
#define NATIVE_SHORT 2
#define NATIVE_CHAR 1
#ifdef __LITTLE_ENDIAN__
/* Native machine byte orders */
#define DOUBLE_ORDER 0
#define FLOAT_ORDER 0
#define LONG_ORDER 0
#define INT_ORDER 0
#define SHORT_ORDER 0
/* Translation matrices from little endian to native */
/* Double format: */
static int dbl_cnvrt[] = {7, 6, 5, 4, 3, 2, 1, 0};
/* Float format : */
static int flt_cnvrt[] = {3, 2, 1, 0};
/* Long format : */
static int lng_cnvrt[] = {3, 2, 1, 0};
/* Int format : */
static int int_cnvrt[] = {3, 2, 1, 0};
/* Short format : */
static int shrt_cnvrt[] = {1, 0};
#else
#define DOUBLE_ORDER 1
#define FLOAT_ORDER 1
#define LONG_ORDER 1
#define INT_ORDER 1
#define SHORT_ORDER 1
/* Translation matrices from big endian to native */
static int dbl_cnvrt[] = {0, 1, 2, 3, 4, 5, 6, 7};
static int flt_cnvrt[] = {0, 1, 2, 3};
/* Long format : */
static int lng_cnvrt[] = {0, 1, 2, 3};
/* Int format : */
static int int_cnvrt[] = {0, 1, 2, 3};
static int shrt_cnvrt[] = {0, 1};
#endif
-------------------------------------------- Managed by Request Tracker
